My Express build
francois2000
My Express build
Post by francois2000 »
Hello,
This is a link to my Express pictures.
http://www.internet.uqam.ca/web/t6762/express.html
I use the Allyn Meyers’ chassis and the ToneSlut transformers.
Thanks Amp Garage
Last edited by francois2000 on Fri Aug 06, 2010 10:19 am, edited 3 times in total.
Re: My Express build
Looks really nice!
Nice clean build. :D
Where are you from?
I take it English is not your primary language?
francois2000
Thanks Tom
I’m from Montreal, Canada. I added my location in my profile.
My primary language is French.
François
François
Good looking build. The chassis shows a nice and clean build. I like your choice of black cab and that faceplate is cool. Did you do the cab and faceplate yourself?
francois2000
Thanks Mark
I built my cab. I took my faceplate at frontpanelexpress.com.
I drew it with a Front panel express’ software.
François
drhulsey
Post by drhulsey »
francois2000 wrote: ...This is a link to my Express pictures...
Félicitations :!: :!:
Great looking amp 8)
Tim
François
Those face plates could be a good thing to offer on the forum.
Ces plaques de visage pourrait être une bonne chose à offrir sur le forum.
Rimy
Post by Rimy »
i just ordered a front and back faceplate for my new build.
confirmed shipping date tuesday 13.
i let you know how they are and i'm gonna take some new pics.
ralph
francois2000
My faceplate file is there http://www.internet.uqam.ca/web/t6762/f ... tFinal.fpd
This file works with a Front Panel Designer software at frontpanelexpress.com
My front panel fits perfectly with my Allyn Meyers chassis except the lamp hole is 0.375 inche. It’s a little small. I used a round file for that.
If you use a chassis cover, it’s a good idea to add about 1/8 inche for that.
François
François
Thanks for the information. Not sure if I am smart enough to use the data.
mss1
Post by mss1 »
francois2000 wrote:Hello,
Thank you Amp Garage
Great Job!
Got any sound samples?
MSS
francois2000
Thanks MSS
Now, I don’t have samples. Maybe if I play in a studio, I'll have them. Sometimes I play with a friend at studio Économique in St-Henri.
François,
I finally got to working with that faceplate file you gave but I did several workups before I remembered you gave me your file. It was easy except remembering to enter the right size holes. Thanks
francois2000
Mark,
The thickness of this faceplate is 2.0 mm. It’s thick with Allyn Meyers chassis. It’s good for PEC or Clarostat pots, I’m used these in my Express. Perhaps with Bournes is ok. I never used this pot. I think it’s too thick for Alpha pots. I hope your pots are good for that.
The software works well, if you first make all holes with their sizes. Second, you write. After that, if you change hole or hole size is more difficult.
François
François,
How has your amp been sounding?
I ordered a face plate and it looks fantastic so I wanted to thank you for that.
I want to learn how to insert an engraving object so I will be working on that next.
