Rocket w/ EF86 channel worthy, or just a DC30.
chopstuck
Post by chopstuck »
I have had an epiphany with the Sting/Stang Ray. Very nice sounding amp with a Tele. It stays on the "edge" and gets some good "grit" with a single Celestion alnico Gold. Now I love my 15w Lightning and Spitfire clones as well as Dart's ef86 lite, but I want to combine the "Rocket with the Ray" into one amp. Kind of a DC30 morph.
Could the hybrid still sound removed enough from the Matchless to make it a worthy build ? Could it still retain each amps identity/ voice since the power sections are so similar ? I plan to use a TS PT and Hammond choke and possibly a Dynaclone or TS OT.
Any opinions ? The EF preamp seems quite compact and space shouldn't be an issue.
dave g
Re: Rocket w/ EF86 channel worthy, or just a DC30.
Post by dave g »
Does the Rocket sound far removed enough from an AC30 to make it a worthy build? :lol:
I'd say go for it. You'll probably like it. Keep in mind, though, that the amp will probably have less gain than either a Rocket or a Stang Ray due to the tonestack loss. You could bias the phase inverter a bit hotter to make up for the lost gain.
chopstuck
Post by chopstuck »
When combining the preamps with their own tone stacks, EF86-Zodiac and 12ax7-Treb & Bass, Do you lose gain as the active channel gets loaded down by the unused channel ? or lost in the mixing resistors ?
Ideally I wouldn't want to have to hard switch between channels but I would if it was the only way to preserve the character of each preamp.
dave g
Post by dave g »
Whoops, didn't see the part about the multiple channels. I thought it was just an EF86 front end.
The loading is all going to depend on how you tie the two channels together. How were you planning on doing it?
chopstuck
Post by chopstuck »
That was was going to be my question. Simple would be best- mixing resistors, but would it isolate the channels well enough ?
Chopstuck,
I also love my Stangray for its clean with the open back 212 blues. I also like my Spitfire clone for its chimey yet has an ability to get great crunch in an amp called 15 watts but with my 18 watt trannies I think it is putting out more watts.
I have been reviewing the Stangray layout and schematic as well as ceriatones layouts trying to figure out exactly what I want. I notice that most are using the EF86 with 12ax7 and I think I should run another 12ax7 (three tube preamps) for more gain. But I still want it to be able to have a clean head room before kicking in the crunch. So maybe just add a VVR and be done. Otherwise will be running the vol knob all night.
chopstuck
Post by chopstuck »
Well I just finished a budget special- a half strength St*ng ray. My Pinto-ray.
I cobbled together an old Zenith extension cabinet chassis and a big Bogen 7868 OT. It sounds great, (after I remembered the conjugate filter). Totally different from my Spit, Lightning and my EF86 powered 18 watt lite. The PT is too hot at 350-0-350 but I cathode biased the el84s with a shared 300 ohm Rk. I hope to do a little voltage reduction soon. I tried a few OTs and the Bogen just spanked all the rivals. Big frame unit.
It sparkles without the hash. Stays clean up to 1:00-2:00 and just a little bit edgy after that. I suppose I could change the PI but I love the clean sound so much more than a Spit. Much more character.
I think I like prototype enough to go for a full on 30 watter with proper Heyboer iron.
I'm going ahead with the Rocket-Ray idea. The way I see it, it adds maybe $10 worth of parts, some head scratching..... and $25 tube.
Chopstuck,
Keep us posted on the Rocket-Ray. I haven't started yet too busy buttoning things up on another build.
chopstuck
Post by chopstuck »
Well I opened up the Pinto-Ray and changed the 7.5k grid stoppers for 1.5K and... what a difference. I guess it was biased cold with the 300 ohm Kr but the increased drive helped warm it up a lot.
I have also finished my 4 holer in a Layfayette chassis and am very happy. It gets a little weird and bass farty on breakup but I attribute that to old power tubes and/or inadequate filtering. Should be easy enough to remedy.
You may need to go with adjustable bias instead of cathode unless it is working fine now.
Glad you got the amp together.
