rocket transformers
paisley_tele
rocket transformers
can i use these trans for the rocket
https://taweber.powweb.com/store/025130sch.jpg
https://taweber.powweb.com/store/041318sch.jpg
Re: rocket transformers
The PT might be OK if you use the lower VAC taps>540VAC. The OT is probably lamo, look for something better quality around 4000 ohms primary - NOT 5600 ohms - and with 3 taps, 4-8-16.
paisley_tele
would a hammond 125e work
Are you planning on a full Rocket build or just a 2 holer.
They run heavily biased and the 4 el84s will take ~180mA.
I might be wrong, but that PT looks a bit light for a full Rocket build and you will require something more stout.
"would a hammond 125e work"
Not nearly...It's rated at 15 watts at limited bandwidth; one of the trademarks of TW designs is the overspec'd power AND output transformers. IMO, if you skimp here, you will build an amp; just don't expect it to sound/perform like a TW. Check the specs of the old DYNACO A470 OT; this is basically what KF used in the ROCKET. It weighs in at about 7 lbs; the 125E is about 1.5 lbs. The DYNACO is reted at 70 watts @ 30-15khz...compare that to the 125E. Hope this helps...
Besides the Heyboer PT HTS-9144 and OT HTS08093-1 what other trannies would work for the Rocket build.
CH Hammond 158L
CH Hammond 158L
Mark - Was that a question?
One OT that I did find that looks pretty good for a Rocket or Liverpool, if you are interested in AC30 tone, is the new Hammond piece that's being made for a Traynor amp. Its 4-8-16 and its primary is 3900 ohms - primary specs that match the OT in An AC30 - and its pretty big, rated at 50 watts. Worth looking at I think, but not cheap.
What I wish is that Hammond - or somebody - would make a 30 watt OT with a primary of 7800 ohms with output taps of 4-8-16-32. This way, you could run either a pair of 6V6s - or a quad of EL84s,which would reduce the primary to 3900 ohms and the output taps to 2-4-8-16. Man, this would be ideal for my needs. Eh, dream on I guess.
Happy Thanksgiving to all who visit this site, BTW. This is a great site with some great members.
Rooster
Yes that was a question. I have read the posts and know what Heyboer trannies to use but since they are hard to get I was wondering if there are other trannies I could use like the Hammonds or others. I did get ahold of RJ and he also noted the A470 is being used but I am not against using other brands of trannies for my own personal amp builds.
Mark-
If Roger doesn't have any 470s left, try Triode Electronics "Dynaclone" 470 OT; available at the address below:
http://store.triodestore.com/
The correct parts for a TW build seem somewhat pricey until you consider what a "real" TW would cost you to purchase (IF even available!) AND the quality of what you will end up with, even compared to other "BOO-TEEK" amps around today.
Hope this helps...
Hope this helps...
OK I ordered the A-470S from Triode and the 158L choke from Parts Express so I am still looking where to get the Heyboer PT HTS-9144. Any ideas guys?
I have already talked with toneslut and others about getting this tranny and no luck so far. Thanks
The 9144 is 250-0-250. The Toneslut PT is 260-0-260. Oh, and by the way, there's like a 20% tolerance on these things....
The Toneslut will work fine and, for all practical purposes, is the same thing but with some extra taps.
Maybe I got confused because when I talked with toneslut he said didn't stock the tranny set for the rocket and so I assumed he didn't have what I needed, but looking back I think he was just saying he did carry the heyboer OT and uses the A-470S instead. I will have to email him and see if that is what he meant.
