I am starting a 15W wreck style to be used with a 1x12. I've heard clips and seen the pics of TWs on Marshall 4x12 bottoms - sort of a definitive TW setup. 1x12 combos though are usually open, one reason because there are tubes in there that need cooling air. Assuming I am not building a combo I could go either way - and it would be easy to switch by changing the back.
In general though, what is the difference in sound that could be expected between the open and closed back? I have the following drivers at the moment - P12N, P12P.
1x12 cab - open back or closed back?
Re: 1x12 cab - open back or closed back?
I know the P12N sounds good in an open back cab. you could do a cab back with a removable panel too. Cab material makes a difference too. For a 15 watter I would tend to go with 5/8" solid pine and 1/2" ply baffle and back. That is if you value the sound that a good sounding cabinet can contribute.
The other way would be, high quality ply all the way around, 3/4 maybe. Less cab sound coloration perhaps.
Yeah. I've done some more searching of this site and others. Open back is more airy, chimey-er. Easier to hear on stage if you aren't right in front of it. Closed back has more thump, tighter bass, better for OD sounds. Closed - think SRV, Hendrix. Open - think AC/DC, Clapton.billyz wrote:For a 15 watter I would tend to go with 5/8" solid pine and 1/2" ply baffle and back. That is if you value the sound that a good sounding cabinet can contribute.
I'm going to have to make it a convertible cab just to try it out.
I find smaller cabs such as for 1X12" size don't offer that much with a closed back, the volume just isn't there to make it work, but, I've found some to sound really cool with fairly narrow openings, almost ported per se.xk49w wrote:I am starting a 15W wreck style to be used with a 1x12. I've heard clips and seen the pics of TWs on Marshall 4x12 bottoms - sort of a definitive TW setup. 1x12 combos though are usually open, one reason because there are tubes in there that need cooling air. Assuming I am not building a combo I could go either way - and it would be easy to switch by changing the back.
It's something that's easy enough to play around with, as you already mentioned.
I think it takes a fairly large 2X12 and on up to 4X10/4X12 sizes before there is enogh volume to get a benifit from a closed back cab.
YMMV
Randal
Blues Junkie
Blues Junkie
