Over the last several days I’ve noticed that the tone is getting more and more overdriven. As it currently sounds with a pair of good SED EL34s, I cannot set the amp higher that 1.5 (about 8:30 oclock) without it breaking up. I checked all the voltages again, and nothing has really changed. I pulled the SED, and replaced them with a pair of JJ EL34s. With the JJ’s, I get quite a bit of the headroom back. That’s good, but it’s got me puzzled. I had plenty of headroom with the SED when I first used them. The bias is set to 42ma. Another thing I noticed is that V4 glows quite a bit brighter that V5. If I turn the amp up to around 9 – 9:30 and turn my guitar all the way up and pound a chord, V4 brightens up and then dims down again to its normal glow. V5 doesn’t do that at all when I pound a chord.
Please forgive my novice/ignorant knowledge here. Just trying to figure out what’s up.
FWIW: On a positive note I put a JJ ECC81 Gold Pin in the V1 slot. Great sound…AND a much lower hiss level. I like it!
Thanks for your help!
Distortion problem with Express build
Re: Distortion problem with Express build
If you could post a voltage chart, that might help.
No problem. At work at the moment. I'll post voltages later this afternoon.gearhead wrote:If you could post a voltage chart, that might help.
Thanks.
ECC81 will also provide less signal amplification than the "normal" 12ax7=ecc83. Result could be distortion later on the dial but around the same volume point in this application. Max setting could be less sustained/distorted than ecc83.
Of course this is not on the original topic.
I see. I was just trying to lower the rush of hot steam that emanates from the amp (i.e., hiss).jjman wrote:ECC81 will also provide less signal amplification than the "normal" 12ax7=ecc83. Result could be distortion later on the dial but around the same volume point in this application. Max setting could be less sustained/distorted than ecc83.
Here is my voltage chart:
b1=409
b2=395
b3=313
b4=294
b5=279
v1:
1=208
2=.6
3=1.8
4=3.3
5=
6=181
7=
8=1.4
9=3.3
v2:
1=262
2=7.0
3=3.0
4=3.3
5=
6=
7=
8=
9=3.3
v3:
1=192
2=25
3=38
4=3.3
5=
6=205
7=24
8=38
9=3.3
v4:
1=
2=3.3
3=408
4=392
5=34
6=397
7=3.3
8=
v5:
1=
2=3.3
3=408
4=393
5=34
6=398
7=3.3
8=
b1=409
b2=395
b3=313
b4=294
b5=279
v1:
1=208
2=.6
3=1.8
4=3.3
5=
6=181
7=
8=1.4
9=3.3
v2:
1=262
2=7.0
3=3.0
4=3.3
5=
6=
7=
8=
9=3.3
v3:
1=192
2=25
3=38
4=3.3
5=
6=205
7=24
8=38
9=3.3
v4:
1=
2=3.3
3=408
4=392
5=34
6=397
7=3.3
8=
v5:
1=
2=3.3
3=408
4=393
5=34
6=398
7=3.3
8=
Voltages are at a proper ratio. What tranny are you using? The B+ is about 15-20 volts higher than my builds. I use Pacifics though. The ratios are correct though. You might want to try biasing around 38mA and seeing whats what. Remember, the proper tubes are NOS Siemens EL-34's and Tungsram 12ax7's
I'm using the vintage Heyboer tranny from Toneslut. I set the bias at 42mA, based on the 70% rule. I'll drop the bias down to 38mA, as you recommend. Aren't those NOS Siemens a ton of doe?Allynmey wrote:Voltages are at a proper ratio. What tranny are you using? The B+ is about 15-20 volts higher than my builds. I use Pacifics though. The ratios are correct though. You might want to try biasing around 38mA and seeing whats what. Remember, the proper tubes are NOS Siemens EL-34's and Tungsram 12ax7's
They go for about $99.00 a pair.
