Hi guys
I'm trying to track down the mini toggle bright switch for my express,
I believe they are an on/on/on switch?
anyone know where to source them from.
Cheers, Craig.
Express Bright (Mini Toggle) Switch
Re: Express Bright (Mini Toggle) Switch
Radio Shack part # 275-325 . It is actually a center pos off so it is on-off-on
Thanks Dana
Cheers, Craig
Cheers, Craig
I can source some 2 amp 250vac versions locally (australia)
compared to the 10 amp ones from radioshak.
would these be OK ???
Cheers Craig.
Cheers Craig.
Yes, its fine.
Find it hard to believe the other one is rated for 10A.....
Thanks fishy
Cheers,Craig.
Cheers,Craig.
- Noel Grassy
Not to confuse folks with the wrong switch. :arrow:A related observation--
I've noticed DPDT On-On-On switches are increasingly harder to find in any configuration. They're also quite expensive compared to their brethren.
I use them in guitars for that "coil cut, parallel, series" thing some folks like in their dual humbucker equipped axes. Maybe that's the switch's sole reason for existence. The demand just aint there I suppose.
Have fun!
Have fun!
