I tweaked a little to tame the brigthness in my TW and tested to remove the whole brigth switch from the circut. I lost nearly all gain and more the 50% of the volume! Can someone tell me whats going on there?
Thank you!
						Removal of bright switch, whats going on??
Re: Removal of bright switch, whats going on??
Check for a bad solder joint on the volume pot.  If you used shielded cable to the volume pot make sure you are not grounding the signal.  Good luck!
