kometious astroid 60w build - question about bias resistor
Roe
Post by Roe »
how do I get 240v with the HTS-8593? Do I hook up the commons (black and purple) and the two 120Vs (white and blue)?
here's the color codes:
HTS-8593
Primary # 1
Common Black
100 Volts Black/White
120 Volts White
Primary # 2
Common Purple
100 Volts Purple/White
120 Volts Blue
thanks in advance
rhinson
Re: wiring up the heyboer HTS-8593 PT (60w build)
Post by rhinson »
Roe wrote:how do I get 240v with the HTS-8593? Do I hook up the commons (black and blue) and the two 120Vs (white and blue)?
HTS-8593
Primary # 1
Common Black
120 Volts White
Primary # 2
Common Purple
120 Volts Blue
thanks in advance
to get 240v you hook the two 120v primaries in series. just hook the white to the purple, stow the leads away, and now you have your 240v pri. with the black and blue as the 2 leads to use. rh
Roe
Re: kometious astroid 60w build - question about bias resistor
Post by Roe »
thanks!
this is my take on the kometous astroid by the way
rhinson
Post by rhinson »
Roe wrote:thanks!
yep. i know those transformers well. :wink: rh
Roe
Post by Roe »
pic
Roe
Post by Roe »
another
Roe
Post by Roe »
whole chassis
marshmellow
Post by marshmellow »
Man, that looks terrific! :D
Nice and clean!
What circuit are you following?
The only thing I can offer is watch running your B+ too close to any ac wires.
I had one of the wires from my standby switch too close to a supply line and I was picking up some noise through the OD channel.
Roe
Post by Roe »
thanks! this amp is inspired by the komet 60 amp that ken fischer designed for hogy
Roe
Post by Roe »
I had to increase the 470 bias resistor to 4k7 or 10k to get the right bias range with mullard ri el34s - have anyone else had this problem with a komet or astroid build?
Roe
Moto
Post by Moto »
OK, I'll bite:
Roe, what is this Holy Grail Cap you're using?
I'm slowly progressing on my K-60 project: it's still very rough, but so far I don't think I'll need to stray from the 470 value for the bias resistor. I'm currently using SED EL34s.
Great looking build, by the way.
UR12
Post by UR12 »
Moto wrote:OK, I'll bite:
The Holy Grail caps are just Cieratone's house branded caps that Nik has made for him. They are just standard caps except his values are 22uf and 47uf instead of 20uf and 40uf like the Mallorys
Roe
Post by Roe »
nik's caps are 100uf. I'll install 4 80uf mallorys soon. (i just have 3 of them now)
Roe
Post by Roe »
this amp is alive and kicking! sounds almost like a cross between my express and '68 jmp50 .
It sounded killer with sec c 6l6GCs today. I'm gonna install the footswitch this summer.
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
