What pots are you using?
BBQLS1
Post by BBQLS1 »
Resistors?
Caps?
Fredaxis
Re: What pots are you using?
Post by Fredaxis »
I am preparing my Express build.
Pots are Clarostat
Resistors are mainly Xicon CF 1W, apart from some RN65 at some sensitive places.
Signal caps are Mallory OD.
Power caps are Mallory
OTOH, I finished my 6V6Plexi were I used Alpha pots (volume not going to zero :evil: ), RN65 all around except at the Pi plate CC. Signal caps are Mustard all around and JJcap cans.
dave g
Post by dave g »
I like PEC pots better than the Clarostats. Xicon 1W CF, and Mallory PVCs.
skyboltone
Post by skyboltone »
Alpha on the current build
Almost all Vishay RN-65D resistors
All PSS orange drops
Filter caps are 47s xicon and 22s Nichicon
Dropping resistors are Vishay Metal Oxide
Screens are wirewound.
When I do the real express build I'll use PEC or Clarostat with the full Mallory set I got from Allyn.
Does anybody know why KF used 5 watt grid stoppers??
Dan H
gearhead
Post by gearhead »
I like PEC pots too; the PECs are smoother than Clarostats and have found a good source for them in Log/Audio.
And of course the Mallory PVC for most signal caps and Mallory TC for power filter caps.
BBQLS1
Post by BBQLS1 »
Where are you getting your parts?
Fredaxis
Post by Fredaxis »
Hi BBQLS1:
Chassis from Allyn (cannot be better)
Some other parts from Allyn (boards, signal caps...)
Power caps from Alliedelec
Clarostat pots (AUDIO+ Lin) from Westlabs
Trannies from ToneSlut
Other parts on hand or from Mouser
Inspiration from Ampgarage.com :wink:
BBQLS1
Post by BBQLS1 »
Fredaxis wrote:Hi BBQLS1:
Thanks!
So Far I've got:
Chassis from Allyn
Boards from Dana
Trannies from Toneslut
Gotta start my list of little parts!
gearhead
Post by gearhead »
Also get my signal caps from Allied; those are big orange .1 uF, .022uF, and .0022uF caps. Made by Cornel Dubilier (PVC601, PVC6122, PVC6222).
BBQLS1
Post by BBQLS1 »
Which diodes are you using? The Ultra Fast ones?
riscado
Post by riscado »
fredaxis I doubt that the fact that the volume on your 6V6plexi doesn't go out completely has anything to do with the pots... I could be wrong though, have you rechecked your grounds?
Fredaxis
Post by Fredaxis »
riscado wrote:fredaxis I doubt that the fact that the volume on your 6V6plexi doesn't go out completely has anything to do with the pots... I could be wrong though, have you rechecked your grounds?
Thanks for the answer Riscado,
I do not want to hijack this thread, but we are at least 3 having the "not going to Zero pots syndrom" on 6V6Plexi...
And it is not the pots as I changed them and still have the problem.
More here: http://www.ppwatt.com/node/15580?page=1
rhinson
Post by rhinson »
skyboltone wrote:Alpha on the current build
Dan H
if you mean the 1k/5w screen grid resistors, it's because el34's screens draw a lot more current than other types of common power tubes we use--it's the typical size you see on marshall's, etc. the grid stoppers are the 1.5k on pins 5----in the pics they look like standard 1/2 watters to me. rh
skyboltone
Dan H
Hey RH. It was a misspoke. On one of the layouts around here some wag has put 5 watt grid stoppers on the liverpool schematic. I've double checked with Francesca and other pictures and they are 1/2 watt.
Dan
gearhead
Post by gearhead »
That mistake traces back to the original Ceriatone Express layout. Haven't seen the Liverpool one you're talking about?
