EXPRESS build in progress
Buschman
Post by Buschman »
I have a good start on it & just had to show it off. I should be firing her up soon. I used can caps to keep from glueing caps in my amp. I am also installing a triode switch. I was going to include a cathode bias option but decided against it. I did install a cut control & left off the bright switch as I have never liked them.
Lonely Raven
Re: EXPRESS build in progress
Post by Lonely Raven »
How did you do such fine lettering on the faceplate?
Jack of all Trades,
Master of None
drhulsey
Post by drhulsey »
Buschman wrote:I have a good start on it & just had to show it off...
Looks GREAT, inside and out :!: I hope your start-up goes well :D
Boy, those can caps really open up some space in the chassis :!:
Tim
Tubetwang
Post by Tubetwang »
Good shoee!!
One more happy camper!!! :lol:
Buschman
Post by Buschman »
I used a set of cheap stamping tools from Harbor Freight. I then darkened it with a pencil before the clear.
Lonely Raven
Ahhh! Crafty! I thought it was burned in!
Jack of all Trades,
Master of None
drhulsey
Post by drhulsey »
Buschman wrote: I used a set of cheap stamping tools from Harbour Freight.
I thought I recognized that :!: I used a set of those on my aluminum face plate. Everybody needs a set of those :D They have a smaller size, as well, in case you want to use large caps/small caps 8)
http://search.harborfreight.com/cpisear ... &Submit=Go
Tim
