I would suggest to pull all of the tubes out and give us the voltages of the power tube sockets. Of particular interest is the voltage present on the #2 pins (bias voltage). This should be negative relative to the chassis.
If you can list the voltages by the pins it would be helpful. Remember, with EL84s, there is usually nothing on the unused pins 1, 6 and 8.
I agree with Pete that the HT on your power tubes seems wrong and the fact that your light bulb limiter is burning bright are an indicator that something is grounded that shouldn't be. Do realize that many amps will slightly flash the bulb on startup and should then fade to little to no light at all within seconds.
Can you post the schematic that you are working from. If it is not correct, we can get that sorted and perhaps find the correct layout as well.
Is this a kit? If so, model number? And any pics of your build in its current state may help a bunch.
Edit: my phone was not showing me Phil's posts. He is spot on in his comments. Sorry Phil.
