Pretty straight forward with Classictone TW iron and a 10h/100mA/210 ohm choke I had on hand. I'm not sure what this choke will or won't do for the build since it has roughly half the suggested resistance, but I had it so it got bolted down.
I'm going to put the 2nd cathode bypass cap on a relay/foot switch and try out some VVR, MV...volume tamers. I have never liked any "MV" types in any Wreck amps I've owned, but I figured in a by-passable situation I would give it a go.
My only real hang up is not being able to get my face plate cut, but that's easy enough to put on later. The pilot light is the only un-soldering that will have to take place. I also forgot my fuse hole in the bottom
 I usually have fair amount of pitting that makes for a dirtier look. Irony is a real B sometimes.
