26v vs 300v PT?
Oddvar R
26v vs 300v PT?
Post by Oddvar R »
Hi. I was wondering what function the 300v vs 260v on the Trainwreck power transformer has? This drawing is from the Modulus version. (Features 260v and 300v HT taps for fast/slow - speed/comfort switching?)
norburybrook
Re: 26v vs 300v PT?
Post by norburybrook »
Oddvar R wrote: Mon Aug 05, 2019 4:49 pm Hi. I was wondering what function the 300v vs 260v on the Trainwreck power transformer has? This drawing is from the Modulus version. (Features 260v and 300v HT taps for fast/slow - speed/comfort switching?)
I've used this very same transformer for my latest express build. I used the 300v tap only and made the fast /slow from a split plate.
M
Re: 26v vs 300v PT?
This transformer can be used to build Trainwreck Rocket (Lower Voltage), Liverpool or Express.
norburybrook
Re: 26v vs 300v PT?
I'll add that it's a huge transformer and you probably won't be able to mount in traditional Wreck fashion with your OT so bear that in mind if you're planning on doing a wreck build.
M
Oddvar R
Re: 26v vs 300v PT?
Post by Oddvar R »
So there ar two taps for different amps?
RockinRocket
Re: 26v vs 300v PT?
Post by RockinRocket »
Yes, Ken ordered from Pacific a power transformer with 250v and 280v secondary's
Re: 26v vs 300v PT?
Or you can put a switch on back for high/low HT but I never did find that a benefit.
