Couple questions:
I did the 1 ohm resistor bias method. Do people normally take those out after playing a few hours?
At first, the amp was playable, but bad low volume distortion and very quiet. I found the 8 and 16 ohm taps form the OT were touching the back fo the impedance selector (metal). After fixing this, the amp got all its volume but howled due to the OT wires needing swapping at the power tubes. How was I able to hear playing from the amp when the two output taps were shorted even though the OT wires were wrong a the tubes? Just curious.
Working on a Paduak cabinet for this build now:
Thanks to RJ and Rooster for offering parts!
Marty
