Monkeymatic Rocket 64
I pulled a nice pile of components from a pristine 1964 Baldwin 54A chassis. I can't fathom how everything stayed so clean and perfect. Ad said was pulled from a working organ, but I can't see how it ran more than a couple hours in its life before being boxed and shelved.
RJ is sending a chassis, and I'm going to make some vintage-vibe Rocket thing, maybe with digital reverb.
norburybrook
Re: Monkeymatic Rocket 64
Post by norburybrook »
oooh nice...I like re using things , that stuff looks in great shape. Keep us posted with the build.
Marcus
ChopSauce
Post by ChopSauce »
Nice! These parts could hardly "felt down" in better hands than yours. I'm looking forward to see what you'll build with these 8)
If you don't mind one question: why not mosfet driven tank, rather than digital reverb?
I am surprised because I read several negative comments about digital reverb. I suppose it's not that bad if you envision it, though :wink:
I really like the sound of the Accutronics BTDR reverb "brick", and the 15v PSU that Lou designed for it. Allows 30v p-p swing, so you can add verb just prior to PI.
Big thanks to RJ for sending a chassis and Rocket PCB (and extras!).
Here's the populated board:
and the +15/-15v PSU and BTDR reverb boards (PCBs by Lou!). There are two PSU boards (top) and two reverb boards (bottom, one flipped so you can see both sides):
joeboo88
Post by joeboo88 »
Nice!
I am just populating the same board from RJ for my Rocket.
I too like the brick reverb. Mines a pedal I built
Keep us posted
Very nice boards indeed.
I had hidden an old MosValve cabinet in the closet...and guess what. It was designed around a 17" x 8 x 2 chassis! So now we've got a combo.
Because of the way the chassis fits the cabinet, I had to rotate both transformers and squeeze them toward the rear of the chassis, but the hum cancels, everything fits, and I didn't bleed.
I expect higher than comfortable voltages before the 5U4GB knocks it down, so I'm going to use 4x 47uF radial caps in parallel/series to get a 47uF/900v reservoir.
RJ's removable chassis top made working the metal MUCH easier on the drill press. Should do this will all my one-offs!
joeboo88
Post by joeboo88 »
Nice cabinet, you can call it “Monkey valve”.... ok maybe not :mrgreen:
I have the same chassis, RJ does have some cool stuff.
Your build is looking great.
More progress.
romberg
Post by romberg »
The reverb and PS boards are pretty cool. I'm interested how it turns out!
Mike
P.S. It may just be the photo and/or my eyes but it looks like there are no grommets in a couple of those holes?
Correct. Still early going.
RJ Guitars
Post by RJ Guitars »
I'm along for the ride... looks like a great project and I know the Rocket builds tend to be a pretty friendly platform for adding your own flavor to them. I used a 5U4 rectifier in one of my earlier Rocket builds and I thought it sounded really good. Looking forward to the rest of this build.
http://www.rjguitars.net
Up and running. I'm leaving the reverb out until I get the bugs worked.
First thing was getting the dissipation under control--with the original value 47R cathode resistor, plate voltage was 300 and dissipation was up around 170%! Using 90R cathode resistor gave me 320 plates and 95%, and 25 watts clean output into 8 ohms load.
I'm chasing some ground loop hum, though it may just be the proximity of my PT and OT--I had to squeeze them together in order to fit the combo cabinet.
I think I'll add a MOSFET B+ reducer to drop the plate voltage closer to 280, and this will lower the hum a little also.
Updated schematic for this build.
