Rocket PDF file?
Rocket PDF file?
Perhaps I'm losing it in my old age, but I couldn't find the PDF file Matt Taylor did of the Rocket circuit.
This was the one I built and thought most likely to be the real deal. I had heard recordings of Rocket's AC-30 clone (I feel silly writing Rocket's Rocket, no disrespect intended.)
The amp I built sounded very similar to his amp (to me), so much that I almost gave up the idea of building an Express or a Liverpool.
I have raved on a bit too much about them in the past, so I'll quite while I'm ahead.
Yours Sincerely
Mark Abbott
Mark Abbott
Re: Rocket PDF file?
I'll email it to you Mark, I've got it. I dont remember where it is on the site either...
Dave
Dave
May I get a copy of that as well Doc? Please?
Greg
Greg
Dave
Could you either email the Rocket schem or post it? I can move it to the Files section.
Thanks,
Omar
Thanks,
Omar
Tone by misadventure
- Funkalicousgroove
I'd love a copy of that as well!! Funkalicousgroove_AT_Hotmail.com
I'll send it this evening guys when I get home from work - it's on my home computer. Probabally makes the most sense for me to post it to this thread so everyone including Omar can get it..
It's funny that this popped up when it did, as I'm just about to start building either a Rocket or an AC30 w/ the EF86 preamp.
EDIT
attached is the Rocket pdf.
EDIT
Any voltages obtained for the PT? Or Z on the primary of the OT?
Of course there is the extra gain stage, so make it a Trem Rocket while you're at it. The trem circuit from either of these can probably be tweaked to fit:
https://schematicheavencom.secure.powwe ... ornado.pdf
https://schematicheavencom.secure.powwe ... ricane.pdf
I don't know the difference to the trem circuit that duet vs. quartet makes off-hand. I'd be looking at a 15 watter, anyhow.
Bear
Bear
I'm using one of Chris's (Moose) Wreck PT's on the 260V tap, and a Schumacher 4K OT with 4 x EL84's. I believe most AC30 OT's are 4.2K or there abouts.
im sure you guys have seen the schem on page 654 of pittmans book version 4?
How bout the one from Pittman's book Vol I page 374??
The schematic in Pittmans book is a Vox circuit; he just got it from Ken, thats why it has Ken's address stamped on it. It's a much later SS rectified AC30.
Play around with the ss recti vs the tube recti schems for more insight into Rocket topology.
CB
CB
Chimeboss, I don't have TAB, so could you do a quick elaboration?
Bear
Bear
