Komet style cab mocha stain built by friend Clarke, Komet 60 style faceplate and custom chassis.
I have been thinking about this build for a year even with so much else going on I had to followup on getting the cab done and parts in to start later this month.
I will use standard 100w Marshall plexi Magnetic Component transformer set rather then 300-0-300 PT and 3k3 OT the Meyer Stadium 80 uses and I will be using a pair of KT88 tubes.
Stadium 80
Stadium 80
Re: Stadium 80
Re: Stadium 80
Looks like the start of a great build Mark.
Re: Stadium 80
Thanks Dave.
How you been buddy?
How you been buddy?
- RJ Guitars
Re: Stadium 80
Hey Mark, I always enjoy following along on one of your builds... are you going to use a tune rectifier on your build?
http://www.rjguitars.net
andresound
Re: Stadium 80
Hey Bob
Where can I buy a tune rectifier??? Can I get one for rock????
If it sounds good, it is good! Trust your ears
Re: Stadium 80
Thanks Bob, no tube rectifier on this one.RJ Guitars wrote:Hey Mark, I always enjoy following along on one of your builds... are you going to use a tune rectifier on your build?
I actually have been trying to stay away from tube rectifiers. I'm not so convinced people are experiencing tube sag. Can always add a sag resistor.
- RJ Guitars
Re: Stadium 80
Yeah,I tend to agree with the no rectifier on the big amps. I just saw that Komet layout and was curious if you were going to follow it.
