Cab sim for a wet/dry express?
naciketas
Post by naciketas »
Hi guys, thank to these pages, I build a decent clone that I played for month with pleasure. Now I'd like to add some effect to widen the palette of sounds and due to the nature of the beast, I came to the wet/dry combination, so I added a line out.
The idea is to pick the signal from the line out, split it in two to a delay and a reverb (for now), both of which go in stereo to a micro mixer on the pedalboard and finally the main out of this mixer to the PA mixer of the rehearsal room.
At the moment I have only a delay, I use it between the line out and the PA , the resulting sound is much better than using it between the guitar and the input of the amp, but not too convincing. Maybe a cab sim could be the ticket? And which one, a DI box with a cab sim (active as a Mooer micro DI, passive as a Palmer PD-09 jb) or a simple cab sim pedal as a Mooer Trescab?. All your suggestions will be appreciated as always.
Roe
Re: Cab sim for a wet/dry express?
Post by Roe »
the aiken goldbrick simulates a greenback
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
stephenl
Post by stephenl »
BadCat Unleash works great for a wet/dry rig. It has the speaker sim/load, effects loop, and 100w PA. I put an EQ in the effects loop along with my reverb, delay, etc.
Steve
