I've started again.....Rocket
- norburybrook
well it had to happen....
I've started a rocket build....
stage one completed.....
Re: I've started again.....Rocket
That PT looks massive or that is a very small chassis.
- norburybrook
It is massive
Transformers are custom ones made by Dagnall
Chassis is standard 17 inch size.
Marcus
Marcus
- RJ Guitars
Looks like some very nice work... I want to follow along.
http://www.rjguitars.net
- norburybrook
todays progress....
those little El84 valve sockets are a pig to work on with so much going on and a lot of double wires required.
As the transformers were so massive I've had to position them in a non standard way so the OT secondary's have to run the full width of the chassis.
I've put a couple of the board resistors directly on the valves, uses less room and means everything is on one long board.
I'm going to fit a fender jewel 6v light , I don't like those marshall type plastic 240v lamps now I've seen it in place.
things I've noticed;
not a single diode in the entire build.
No relays
no negative feed back so I wont be able to keep up my 100% record of having OT primaries wrong way round
Marcus
No relays
Marcus
Looks great so far.
What are the specs on that PT if you don't mind telling?
I built my twin tube Rocket with a 280-0-280 Edcor unit.
- norburybrook
it's a Vox AC30, 282-0-282 , the guy who spec'd it was very precise about the quality of iron used and the Lamination types etc .I'm not that savvy on transformer internals I'm afraid so can't tell you exactly
Didn't get any more done today...
Marcus
Marcus
- norburybrook
OK, I'm waiting for my pilot light and a new back plate so I can't wire up those things yet but other than that I think I'm done....
few tie wraps and a bit of tidying up and it'll be power up time.......
Marcus
Marcus
Marcus, just curious, can anyone call up Dagnall and order a custom one-off?Transformers are custom ones made by Dagnall
What did you use for resitors?
- norburybrook
rp wrote:Marcus, just curious, can anyone call up Dagnall and order a custom one-off?Transformers are custom ones made by Dagnall
don't see why not http://dagnall.co.uk/ as you're in Italy RP why not use InMadOut their transformers are great, used them for my Dumble BM.
resistors; just your usual carbon film Xicons with a couple of left over Dale metal films. Used up my 6PS orange drops as well from my dumble builds.
Marcus
- norburybrook
finished
what a great sounding amp. Loud , full with a great presence. Lovely top end , sparkly but not ice picky. Nice break up too with my 4x10 marshall cab. Going to try different speakers next to see what works best.
Big thanks to GuitarMike here on the forums for his help in this, he made the boards for me , supplied the transformers/chassis parts etc and helped along the way with my requests for various things
Cabinet is Ash and an Australian hardwood, made by a guy in Ireland , ZD designs, found him on facebook.
Marcus
Marcus
Looks great! Nice head cab. You just know it sounds good
- RJ Guitars
I've said it a few times but it bears repeating, one of the best options the non-USA part of the world has in power transformers for a Trainwreck Express is the VOX AC-30 PT. 282-0-282 hits it pretty close and they come with multiple primary taps. It's a tad higher voltage than the standard Rocket Values but as you have found, they also work very nicely in that amp.norburybrook wrote:it's a Vox AC30, 282-0-282 , the guy who spec'd it was very precise about the quality of iron used and the Lamination types etc .I'm not that savvy on transformer internals I'm afraid so can't tell you exactly
Marcus
- norburybrook
yes my voltages are slightly higher than the one posted in the rocket files section but it makes for a great sounding amp.
The EH pre amp valves and JJ EL84's sound really good.
Marcus
Marcus
guitarmike2107
Totally true, but as was found out here the AC30 Iron is taller and wider than std wreck iron which presents its own minor issues, layout & cabinet etcRJ Guitars wrote: I've said it a few times but it bears repeating, one of the best options the non-USA part of the world has in power transformers for a Trainwreck Express is the VOX AC-30 PT. 282-0-282 hits it pretty close and they come with multiple primary taps. It's a tad higher voltage than the standard Rocket Values but as you have found, they also work very nicely in that amp.
I have a build on the way with the same transformers that Marcus used.
If there is demand I may get proper sized wreck trannies made for the EU.
Marcus, it looks super smart and the cab looks stunning too, well done mate.
