Replacement lamp blows fuse and lamp in Rocket
davidskywalker
I replaced the traditional amber lamp in my Rocket with a Jewel style, but not traditional fender, that is 125V@75Watts and blows the bulb and fuse. Doesn't seem to be making a ground from what I can see. Here is the link to the bulb I'm using: https://www.tubesandmore.com/products/P-L110
Any suggestions on how to install this type?
David McCoy
- pleasantbullet
Re: Replacement lamp blows fuse and lamp in Rocket
I used the same for my express, with no problems.
Could your fuse blow if you use the wrong bulb?
davidskywalker
Can you give me a value for the bulb you are using?pleasantbullet wrote:I used the same for my express, with no problems.
David McCoy
Have you actually measured the resistance between the socket (both sides) and ground?davidskywalker wrote:I replaced the traditional amber lamp in my Rocket with a Jewel style, but not traditional fender, that is 125V@75Watts and blows the bulb and fuse. Doesn't seem to be making a ground from what I can see. Here is the link to the bulb I'm using: https://www.tubesandmore.com/products/P-L110
Did you read the base of bulb to ensure it was correct?
Where do you have it connected to the circuit?
- johnnyreece
Just checking...you aren't using a 6.3v bulb with 120v are you?
- pleasantbullet
https://www.tubesandmore.com/products/P-47
i use this bulb with the fender style lamp.
and hook it up to the filament supply, rather than the 120.
davidskywalker
Yea...I did hook it up to the 120V instead of the filament. I'm a beginner amp builder and electronics student but makes sense now.pleasantbullet wrote:https://www.tubesandmore.com/products/P-47
Thanks for the quick response!
David McCoy
- RJ Guitars
The fixture is rated for 125V so I am a little surprised that a 6.v bulb was stout enough to blow the fuse... usually they last a couple micro seconds as they go out in a flash of glory. The typical slow blow fuse will outlast that event so I don't entirely understand but in the end if it's all working, continue on down the path.
http://www.rjguitars.net
davidskywalker
Was confusing and was told by another that it should work fine, It only lasted for less than a second as the fuse. I hooked up using the filament supply and now works great.RJ Guitars wrote:The fixture is rated for 125V so I am a little surprised that a 6.v bulb was stout enough to blow the fuse... usually they last a couple micro seconds as they go out in a flash of glory. The typical slow blow fuse will outlast that event so I don't entirely understand but in the end if it's all working, continue on down the path.
David McCoy
