Some of the voltages are a departure from what is listed.
I am concerned at how hot this amp is running. I find in hard to touch the amp any longer than 20 seconds. The tubes are all running at and above their specification which is a worry, especially in a wooden cab. I wonder if the flash point of the finish has to be considered?
 I'm thinking of using a zener to lower the voltage 290 or 300. Though Allyn stated:
https://tubeamparchive.com/viewtopic.php?t=5866&start=0Voltages are dead on for the Rocket I copied. B+ is very low (like the originals) around 270VDC-275VDC.
I have used a zener to get the amp to 265VDC and it loses a lot of treble and vibe.
Allyn also makes this point:
My amp has about 81VDC on V1 with the higher rail.100V +/- 5 on V1 (like the original.
All thoughts welcome.
