More Headroom on Rocket - Plate Bias Resistor?
davidskywalker
Post by davidskywalker »
This may seem a bit basic, but I'm looking to get the best headroom on my new Rocket build. I know that if I use the 280V instead of the 250V I'll get more headroom, but I've been informed to change the plate bias resistor. However, I did notice on Ceriatone's Rocket layout there is a voltage switch to go back and forth. Can you guys shed some light on this or point to a good post on this?
David McCoy
Re: More Headroom on Rocket - Plate Bias Resistor?
Change the 220k plate resistor of V1 to 150k or 180k and can increase voltage to V1 as well by lowering the dropping string resistor from the filter cap.
Using a switch you can switch between 250 or 280 HT leads but it really isn't worth it in my experience I like the higher plate voltage. I've ran JJ el84's without problems on the stock Rocket bias resistor with the 280-0-280 HT.
Post by Mark »
Perhaps at the input to the PI (after the 220K resistor) you could put a 220K to earth thus forming a volume divider. This would allow you to still get the same compression from the cathode follower whilst having a smaller signal getting amplified by the P.I. stage.
Yours Sincerely
Mark Abbott
