Fender vibro king 2x12 loaded with v30's ?
andresound
Has anyone tried this configuration? Will it work with an Express?
If it sounds good, it is good! Trust your ears
Re: Fender vibro king 2x12 loaded with v30's ?
One G12H30 with a V30 or two G12H's would be preferable for myself.
andresound
Thanks Clyde,
I picked one of these cabs up at a good price without auditioning it. It sounds very "dull", as in no top end! I will open to check if driveres are out of phase. Although it is wired as a 16 ohm cab. Is it still possible it could be out of phase?
I read on the forum that v30"s are generally "ice picky". This cab sounds the opposite
andresound
If drivers are in phase, I will sell one V30 and install G12H30 or a ALBION (Wharfdale) G1280-VSR, which is what I was comparing this cab to. The ALBION single 12 (open back) sounds louder and much more "bell like" or "sparkly" than the 2x12 closed back.
FWIW, the G1280 VSR is a great sounding speaker, IMO!!!
Try the Fender section, that might get better results.
Yours Sincerely
Mark Abbott
Mark Abbott
