Whose got a extra set of KF NOS Rubycons?
				RockinRocket
Any one willing to sell a set that matches the photos of expresses we have seen?  I am trying to get as much nos parts as possable. Im in no hurry im most concernrd about geting the Rubucons and some fleas and vectorboard. I just cant afford RJS board at this time.
						Re: Whose got a extra set of KF NOS Rubycons?
Edit: Sorry, didn't read Express and thought you meant LP.
Good Luck with that.
Seriously - you'll need it.
Why Aye Man
				RockinRocket
Blackburn any chance you have the Rubycon V1, V2, cathode bypass caps? I believe the 22uf 25 volt are the same for Liverpool and Express.
				Cliff Schecht
Eh, I have a few I pulled from an 80's keyboard, but I wouldn't trust them as far as I can throw them. I'd offer them up but they're in Austin and I'm not.
A lot of people have been down this road only to find that such parts really don't make a difference, like at all. They aren't in the signal path directly and only have an influence on the overall response of the stage, they are not passing signal per se. Even if the caps DID sound better somehow at that time, they're well past their shelf-life now and won't be performing to the same standard regardless! Have fun in your quest for tone but be aware that you are using "expired" parts based on older technology.. The e-caps nowadays work fine and if you can hear a difference, then you truly have a set of golden ears .
.Cliff Schecht - Circuit P.I.
The only Rubys I have are 220uf 63v that are good for the LP/Rocket. If you need those, I have a bunch.RockinRocket wrote:Blackburn any chance you have the Rubycon V1, V2, cathode bypass caps? I believe the 22uf 25 volt are the same for Liverpool and Express.
