New Rocket with Pacific Transformers and Modifications
gktamps
Post by gktamps »
Hi Gang!
Just completed this new Rocket tribute, using Allyn's Pacific transformers and chassis, and it is a gem!
In my past four Rocket type builds, I have experimented with and implemented several different approaches to adding adjustable, additional levels of gain with the goal of maintaining the essential character expected of a Rocket. This build incorporates several of these and more, and omits several approaches others here have used.
1. Switchable 50pF or 50+500pF parallel treble caps.
2. Switchable .01uF or .01uF + .01uF CF caps.
3. Variable 0-250k PI input resistance (pot).
I've also gone with an adjustable treble bleed for the volume pot, using a tiny 100k pot with a 500pF cap, just for kicks, and to see if I could, and I used a Russian NOS mica cap (odd looking thing, isn't it?).
One change to the circuit is the use of NOS Russian PIO caps in the .047 and .022 (and my .01) positions, and the heretical use of a filter cap board (in for a penny, in for a pound), though I did return to the traditional chassis-mounted power tube cathode resistor. To bring the plate dissipation down a bit, I started with a 60 Ohm resistor, but may drop it down, perhaps to 57 Ohm or so.
This time around I didn't install an HT fuse for the OT, and hopefully this wasn't a mistake.
Grounds follow my previous distributed star arrangement, and the amp is exceptionally quiet.
There are spare turrets on the board for 2 different V1a bypass caps, and a jack installed at the rear panel, but no caps at this time (not really in love with what it does to my other Rockets).
It's already becoming the favorite of my Rocket builds, but then again, I am fickle. :lol:
This is the first build in which I've used Allyn's Pacifics. The tone is balanced, and warm, and delicious. I'll post photos now, and try to do a more complete job describing the amp's response later.
All you contributors here on TAG have made builds like this possible for me, and I thank you again for sharing to the group, and many of you, to me personally.
Greg
Paultergeist
Re: New Rocket with Pacific Transformers and Modifications
Post by Paultergeist »
Beautiful! That cabinet -- and the skills which must have preceded the construction thereof -- leave me green with envy!
I have also just finished a Rocket-based build -- my first one -- and I am quite inspired by the results thus far. Like yourself, I made a filter cap board.
I am very interested in some of the switchable mods. May I ask what the "CF" caps (Mod "2) refer to?
Congrats on the build!
Colossal
Post by Colossal »
Greg, that looks real sharp. Really dig the cabinet; a fitting home. How are you finding the mods? Polypropylene output coupling caps? You have been profuse of late.
Very nice!
gktamps
Post by gktamps »
Paultergeist wrote:Beautiful! That cabinet -- and the skills which must have preceded the construction thereof -- leave me green with envy!
Thank you, Paultergeist! The only credit I can take for the cabinet is having the good taste to buy it from Moose a couple of years ago when he put it up for sale here on TAG. I've been waiting for a really nice build to do it justice, and this one is it.
Paultergeist wrote:I have also just finished a Rocket-based build -- my first one -- and I am quite inspired by the results thus far. Like yourself, I made a filter cap board.
I've done it both ways, and the cap board can be more work and take up more room, but does make adjusting the dropping string a bit easier, which is good for a non-stock build, reverb circuit, etc. It's also a good place for the output tube cathode resistor and bypass cap if you don't want to put it on the chassis, and leaves room for VVR if you want to install it. Otherwise, I really don't mind the stack o' caps at all - less wire, brings the caps closer to the preamp board, etc.
Paultergeist wrote:I am very interested in some of the switchable mods. May I ask what the "CF" caps (Mod "2) refer to?
Sure: the stock cathode follower .022uF caps affect the tonal response, and it can balance the amp to drop this value. I've seen .0047, and used it in this position before, but wanted to have this amp switchable from pretty much stock values to altered, so put in two .01 caps on the board with a switched bass pot to parallel them, giving me the choice of .01 or .02.
The treble cap mod makes the biggest difference, affecting the tone and apparent gain. I did that by using another switched pot to parallel a 500pF to the stock 50pF. I like it much better than lowering the .047uF coupling caps, which has been recommended by some folks to moderate some of the bass, which can get to be pretty prominent in Rockets.
Greg
gktamps
Post by gktamps »
Colossal wrote:Greg, that looks real sharp. Really dig the cabinet; a fitting home. How are you finding the mods? Polypropylene output coupling caps? You have been profuse of late.
Very nice!
Thank you Dave!
Yes, that cabinet I really luscious, and I'm glad I bought it from Moose a couple of years ago rather than try to make it. :D
Hah! Fooled you on the output coupling caps. Those are the same NOS Russian PIO caps as the others, but because they are so damned long, they were really close to a couple of turrets, so I sleeved 'em with shrink tubing.
The mods are amazing. Switched out, the circuit is stock, and sounds fantastic. Bell-like, chimey, full, rich, clear, articulate, though with great sustain and easily induced and controlled feedback. Each one has a noticeable effect, so they can be used progressively. When the treble cap is at 550pF the gain kicks up, and of course the frequency response shifts up. The PI input pot (wired CW to decrease resistance) really pushes the aggressiveness by driving the PI hard. Lots of sustain and controllable feedback, while still remaining touch sensitive. I also really like the variable treble bleed capacitance feature, though I need a small-shaft knob that better compliments the rest of the knobs!
One interesting thing is that the Russian K40y-9 caps are so spot on with their rated values, it's incredible.
Having said all that, I think this transformer set is the best of all of the combinations I have used. The tone is balanced, warm, (my wife says it sounds "woody, like mahogany", if you will), and not harsh, even with the mods switched in.
Wish I had a good way to record some clips, and the confidence to post 'em up!
Greg :D
Paultergeist
Greg,
Thanks so much for the detailed reply to my questions. I am studying the schematic and taking notes from your posts. Thanks also for the helpful photo. I hope to try a couple of these tone mods soon.
Paul
