Monkeymatic S'express 15-watt
Witness! The inception of my small Express, thus, "S'express".
Thanks to RJ for the inspiration, and to others for the spare parts, including the iron, which is a 1980s tranny set for Rivera-era Fenders. I have taken many liberties with the layout, stealing ideas from Hoffman, Huss, HAD, etc., and completely throwing caution to the wind.
Chassis is a blank from Watts, 12.5" x 8" x 2.5". [updated layout, see next page]
dcribbs1412
Re: Monkeymatic S'express 15-watt
Thanks xtian
Is this a build in the works?
I have a 18watt PT and a DR OT
on the shelf I might give this a shot.
Darin
Darin
I have 95% of the parts, but haven't started building yet. This will probably get built over the next few weeks. I'll keep posting.
Xtian
Is this gonna be a 6V6 version? MV, really??
No, those are noval sockets for EL84. Yes, MV.
Xtian
Nice addition to your amp choices....
dcribbs1412
Will be looking forward to updates
What is your iron specs?
I might see 350V@120ma on the plates using the 290v-0-290v PT
hoping its close enough for a 6V6 xpress.
Darin
Darin
Mine is going to be very low voltage. I'm using a Fender A019118 "Super Champ" transformer, with 310vac unloaded HV. That will probably give me 260vDC on the plates. Might have to throw up my hands and put in a different PT when I'm done...but we'll see.
EDIT: Well, I'm less concerned about the voltage after reviewing the EL84 datasheets, which have a spec for 250 on the anodes of a P-P pair in class AB.
dcribbs1412
What math are you using....Not sure if this is right but I have seen others use 1.2 and 1.4 as a multipliersxtian wrote:Mine is going to be very low voltage. I'm using a Fender A019118 "Super Champ" transformer, with 310vac unloaded HV. That will probably give me 260vDC on the plates. Might have to throw up my hands and put in a different PT when I'm done...but we'll see.
1.2x310V=372V loaded? or 1.4x310v=434 unloaded?
After looking into the load calcs a little further (1.2x290V=348V)
I may only see around 350V at the plates.
Darin
Check out Hammond's Design Guide for Rectifier Use:
http://www.hammondmfg.com/pdf/5c007.pdf
Mine is a full-wave bridge, cap input. V(peak) = 1.4 x secondary HV, and V(average) = 0.9 x secondary HV.
So, I'm multiplying my 310vac unloaded by 0.9, and then AGAIN by 0.9 as fudge factor for value under load.
dcribbs1412
Thanks xtian
good info
looking forward to your build
Darin
good info
Darin
Xtian
But an Express preamp with EL84s? Liverpool??
it looks like its fixed bias thoughJoeCon wrote:Xtian
Ok so a cross between the Liverpool and Express! I like it...
I've got a chassis punched for EL84s maybe I should build one too...
Thanks.
Thanks.
I'm following RJ's lead on this one. Express preamp, EL84 power section, fixed bias. Yup.
