Which one is the "right" schematic??
ChrisGS
Post by ChrisGS »
I see that there are a bunch of variations of an Express type amp . Are any of them copied from an actual Trainwreck amp ?
Also , I have a power transformer that puts out about 425vdc after the rectifier diodes. What kind of voltage do you guys like to see on the plates of the output tubes ?
Thanks ,
Chris .
Robert
Re: Which one is the "right" schematic??
Post by Robert »
The Kelly90 schematic is from a real trainwreck. Most consider the A1a schematic very close. Look in the files section for both as well as info on the transformers. My plate voltage is 392v.
Good Luck.
ChrisGS
Post by ChrisGS »
Wow , that was fast ...Thankyou Robert .
