6v6 Rocket build
Mainetone
6v6 Rocket build
Post by Mainetone »
Hi all,
I built a 6v6 rocket using a Stancor 8404 pt, it has 250v secondaries. Im reading 326v bplus2. The amp sounds great but it wont give me the harmonic feedback I get from my other wreck clones. Any thoughts?
Thanks in advance
PaisleyTube
Re: 6v6 Rocket build
Post by PaisleyTube »
less gain than the Express and/or Liverpool in anyway
Chris
Love, peace & loudness!
Rockets are smooth easy going amps, if you want more balls add 25uf/25v bypass cap to V1b cathode resistor.
You could also use that unused triode of V2 as a gain circuit.
I've tried a lot of different things with my rocket build I found the stock circuit with a range master in front of it to sound better than any of the mods I tried for more gain.
Yes the Rocket takes pedals very well. I want a Range Master pedal got one for sale? Cheap!
Well it looks cheap they are mounted in electrical boxes.the work is so shoddy I would never let anyone look inside much less sell it.both have been through a flood and are caked with mud but still work
It makes the my rocket think I'm Brian may. tie yo mamma down
Ah a true mountain man use what you have :lol:
Mainetone
Thanks for the input
Post by Mainetone »
I added the 25uf cap to the cathode resistor and got some more gain, I ultimately changed the pt to a 600v got the bplus up and the amp screams.
for the input
Zippy
Re: Thanks for the input
Post by Zippy »
Mainetone wrote:I added the 25uf cap to the cathode resistor and got some more gain, I ultimately changed the pt to a 600v got the bplus up and the amp screams.
for the input
Did you adjust the dropping string to keep the V1 voltages down?
Mainetone
Post by Mainetone »
I did,
27k 1.2k and 2.2k
Bplus 5 118
4/163
5/188
Zippy
Post by Zippy »
Nice job.
Thanks.
