Can anyone confirm the part numbers for Allyn's recent supply of Rocket transformers? I bought a set plus a Rocket chassis, but just started this build, and found out I got a Liverpool chassis instead. No worries, as I can simply drill for the rectifier tube, but now I'm wondering if I also got Liverpool transformers.
I've sent Allyn PMs and emails but haven't heard from him yet, so I'm hoping to save some time and get started; have any of you also recently bought Rocket transformers from Allyn this last go-around, and can confirm that my transformer parts 2111 and 2117 are Rocket-correct?
Thank you!
Greg
Allyn's Rocket transformers
Re: Allyn's Rocket transformers
Allyn only sells Liverpool chassis and Express chassis, you have to drill your own rectifier socket hole to use the chassis as a Rocket.
Pretty sure Allyn also only uses one set of transformers for both LP and Rocket.
AFAIK the rocket transformers from Allyn are diferent from the express-liverpool transformers.
- Turbojunkie
Hi Greg,
Yes, those are the part#'s for Allyn's Rocket set....
Adam
Adam
First 25 years of playing, I never got along with EL84's...Now I think, WHAT THE HELL WAS WRONG WITH ME????
Thanks, Mark, I did figure on drilling the hole, but didn't know Allyn provided only Lpool chassis for Rocket. Again, no problem, but it had me wondering if I had the right transformers. I didn't get a wiring color code with these, but can figure them out.
"Hi Greg,
Adam"
Adam, thanks for confirming the part nos.M Fowler wrote:Allyn only sells Liverpool chassis and Express chassis, you have to drill your own rectifier socket hole to use the chassis as a Rocket.![]()
"Hi Greg,
Adam"
