[img
[img
I am not using the cathode follower of the basic kit.
In order to get the noise level down, besides the using wire dressing tricks, I have used shielded cable from the input jack to a 68K grid stopper attached directly to pin 2 of V1, shielded cable from the volume control to the 1K grid resistor for V2 (the 1K is on the board and the cable goes to the resistor on the board), shielded cable between the treble pot wiper and volume control, and shielded cable between the 8 ohm position of the impedance selector to the feedback resistor (56K feedback resistor is about as large as I can go).
The amp is very quiet, almost hum and hiss free at all normal playing levels and sounds reall good with a Strat or humbucker equipped guitar. The primary problem I am having is if I turn the volume all the way up, if I advance the treble control (I used a 250K audio pot with a 250pf cap, it was too bright for me otherwise), at about 3:00 on the treble pot there is a burst of hiss and when turned up all the way the sound is noisy and distorted. Turned back below 3:00 (with the volume dimed) and everything is fine.
The secondary problem is not being able to go higher than 56K on the feedback resistor (which actually sounds good).
The last problem is getting the presence pot to work. It too breaks into noise above 3:00, like the treble. It is currently not installed.
I have read the Ron Worley's Exprees build guide from cover to cover and followed many of his suggestions for building and troubleshooting. Although the JAVA is not physically like an Express, I have made it electrically similar. I am only using a single 100pf bright cap, added a switch to disconnect the V1 cathode bypass cap to drop the gain, and made a few changes to the treble tone control (amp was too bright for my taste).
I'd like to get the treble pot problem fixed first. The other two issues I am less worried about. Any suggestions? I have tons of photos taken during the build if they will help. Thanks in advance.
