Here they are finally! Whipped these out while we were getting ready for mixdown, don't laugh I couldn't think of what to play! Phil http://www.spf-50.com/mp3s/phil/
Thanks for sharing Phil...Playing was just fine....The second clip sounded more open than the first. I know the Rocket uses EL84s but after hearing that last clip I thought there were some similarities in that sound to a Fender Pro-Reverb…Maybe a bit more crisp than a Fender but familiar none the less...Interesting....
If the clips are in the order I gave them to my brother to post clip1 is sg les paul custom reissue through the trem-rocket with no trem, cabinet is mid sixties bassman 2-12 with red fangs wired series for 16 ohms. Clip 2 is express, sg through hiwatt 4-12 bottom cab with celestion g-12m 55hz speakers. Clip 3 is es-335 with lollar imperials through trem-rocket with trem on through the same bassman cab as clip 1. I've since played 3 gigs with the trem-rocket and added a mid control on the back panel. I just got a radial switchbone so I can play both amps through the same cab Now I just need to decide on the cabinet! Phil
