That is, sensitive to noise from anything and everything related to electricity.
This amp reveals everything, not to mention the true quality state of your preamp tubes. Tubes that I thought were good, turned out to be a humming, giant glass garbage cans full of scrap metal, busted up sounding mess in this amp.
If the fridge turns on, I can hear it in the amp. If I discharge a little bit of static electricity near the amp, I hear it... If I blow a fart, and it refracts 10 year old radio waves on planet Mars, I can hear it.
I wonder if I should drag around a power conditioner if I play it out somewhere.
						Is your Express sensitive?
				vibratoking
Re: Is your Express sensitive?
I always bring an AC line voltage regulator no matter what amp I use. All my equipment is protected, operating at a known voltage, and the sound is very repeatable from venue to venue.leadfootdriver wrote:I wonder if I should drag around a power conditioner if I play it out somewhere.
vibratoking wrote:I always bring an AC line voltage regulator no matter what amp I use. All my equipment is protected, operating at a known voltage, and the sound is very repeatable from venue to venue.leadfootdriver wrote:I wonder if I should drag around a power conditioner if I play it out somewhere.
+1
They're expensive ........ and absolutely essential for sanity at gigs where the stage power is on the same circuit as the air-conditioning, elevator motors, commercial freezers, and ham radio tower and transmitter.
