Trainwrecking a 50w Marshall type amp suggestions
newking70
Post by newking70 »
Who's boards should i go with? What about amp iron? Any suggestions would be appreciated. :D
Zippy
Re: Trainwrecking a 50w Marshall type amp suggestions
Post by Zippy »
What is it that you want?
Express?
Octal Rocket?
If you're using a set of Marshall iron, your voltages may be too high.
He wants to do the Express front end on a Marshall power section.
Metro. Google "Wrecked Plexi". You can build it right on your pre-existing turret boad.
paulster
Post by paulster »
That's exactly what I was going to suggest. Mark's 100W Marshall with an Express front end was awesome, and the same mods would apply to a 50 too.
newking70
Post by newking70 »
too evh sounding. :cry:
eddie25
Post by eddie25 »
That guy could play a twin reverb and it would be too EVH sounding. I wouldn't base it off his clips. He's probably playing EVH licks anyways.
newking70
Post by newking70 »
eddie25 wrote:That guy could play a twin reverb and it would be too EVH sounding. I wouldn't base it off his clips. He's probably playing EVH licks anyways.
:D
pablogt
Post by pablogt »
Not sure if it's off topic, but I'm currently working on "Trainwreack layout" for an AX84 October with PPIMV and power scaling. That's basically a Marshall Superlead preamp with jumpered channels and a 6v6 power amp. I'll call it Plexi22
Pablo
Zippy
Post by Zippy »
Reeltarded wrote:He wants to do the Express front end on a Marshall power section.
Got it. Thanks for translating that.
Yes, that'll be pretty straightforward.
So a Komet Concorde 50w or Komet 60w then?
Pablo,
I built an amp similiar to what your layout is showing with hi and low gains.
https://tubeamparchive.com/viewtopic.ph ... ht=swamper
pablogt
Post by pablogt »
Yeah, it is quite similar. I also built a similar preamp before, with a 4xel84 power section. It was originally a Ceriatone 18/36w, but ended up being channel switching (jcm800 / superlead preamp). I added another tube so that the input section was four triodes in parallel (two bright, two dark), like on most Mojave amps. I liked the result, I might do that on the plexi22 too (plexitootootoo??? I love this language...).
P.
newking70
Post by newking70 »
thanks guys for the responses.....i think a komet layout it what i'am thinking about. 8)
Zippy
Post by Zippy »
pablogt wrote:I added another tube so that the input section was four triodes in parallel (two bright, two dark), like on most Mojave amps...
Derail...
I don't know the Mojave amps and am curious about how you are applying these bright/dark pairings.
pablogt
Post by pablogt »
These are Mojave amps http://mojaveampworks.com/amplifiers/. I have used parallel input in most of my builds. My rocket has different cathodes for both input triodes, so I also halved the plate resistor. But in my 18/36w build, I just paralleled the first triodes, without changing cathode or plate resistor values (that's how Mojave amps are designed). The amp fattened and turned "juicier", without notable increase in gain. This is my previous build preamp schema.
P.
