plate diodes
plate diodes
what is the purpose of the three diodes om each power tube?
Re: plate diodes
...to allow flyback voltages (from running without a speaker load connected, say) to drain to ground. If the reverse voltage gets high enough, the diodes are sacrificed to save the OT. See here for more discussion: https://tubeamparchive.com/viewtopic.ph ... highlight=
Re: plate diodes
why is tw the only amp with these?
Re: plate diodes
its not. look around at other schematics.
I had issues with 300W bass amps that ran plates at 500V on 6550s, KT88s, arching tubes. Flyback voltages develop at I believe (-)2*B+ on the opposite side of the primary. Flyback diodes prevent this voltage by clamping to ground. Keeps the tubes safe. Look at old ampeg schematics.
Please correct me if the math or theory is wrong.
Re: plate diodes
He picked it up when he was working at Ampeg. Some of the V Series amps have that, though implemented with a more obscure diode.
Re: plate diodes
then should'nt we do this to all amp builds?
Re: plate diodes
I do.scole wrote:then should'nt we do this to all amp builds?
Diodes
Anyone try the diode from the grid to cathode to keep the grid from turning into an anode? Like on the Fender Pro series amp Pro reverb from the early 2000's?
markr14850
Re: plate diodes
Would this be like the "Paul Ruby Mod" with strategically chosen zeners from grid to ground?Anyone try the diode from the grid to cathode to keep the grid from turning into an anode? Like on the Fender Pro series amp Pro reverb from the early 2000's?
Re: plate diodes
Agreed. That was the intent of my thread on "Bulletproofing an Amp":scole wrote:then should'nt we do this to all amp builds?
https://tubeamparchive.com/viewtopic.ph ... t+proofing
Re: plate diodes
I don't think these diodes are necessary. I've never used them in any of my builds (many), no problems.
Re: plate diodes
Well the grid ones are for tone more than protectionClyde wrote:I don't think these diodes are necessary. I've never used them in any of my builds (many), no problems.
Re: plate diodes
kind of yes but might be a better way to do itmarkr14850 wrote:Would this be like the "Paul Ruby Mod" with strategically chosen zeners from grid to ground?Anyone try the diode from the grid to cathode to keep the grid from turning into an anode? Like on the Fender Pro series amp Pro reverb from the early 2000's?
At least with non cathode biased amps.
Re: plate diodes
Sorry, I should have clarified my posting. I meant the plate diodes. My understanding of the diode from grid to cathode implementation is that it occurs on dc-coupled stages and cathode followers.
Re: plate diodes
The flyback diodes are only necessary normally when you're using high plate voltages. I said 500 earlier, i actually meant 700V. Since i started using flybacks, no more arced tubes.
