Third gain stage in TR
pgambon
Post by pgambon »
I have a TR inspired build. It's housed in a tweed Bassman chassis, and uses Bassman transformers running two 6L6's. The front end is all TR with the addition of reverb.
Here's a mod I did that I thought you might find interesting: on V2b I added a switch to go to either the 150k or a typical Fender 1.5k/25uF cathode resistor and cap. The 150k resistor seems to be a KF trademark, however, I tend to like the 1.5k/25uF set up better. The amp really rocks in this mode. The 150k has a tighter sound, and the amp is plenty loud, but at the end of the day I prefer the Fender values. Any thoughts?
RJ Guitars
Re: Third gain stage in TR
Post by RJ Guitars »
pgambon,
Sounds like a nice mod... any photos, drawings, or sound clips?
thanks,
rj
http://www.rjguitars.net
funkmeblue
Post by funkmeblue »
ken didn't use a 150k cathode resistor, he used 10k
Zippy
Post by Zippy »
Yepper, check the value of R7 as well - that is supposed to be 150K.
R8, the cathode resistor for V2A is typically 10K.
pgambon
Post by pgambon »
Bad me. I am reffering to the 10K resistor on V2a and switching to the 1.5/25uF "Fender" set up.
Zippy
Post by Zippy »
Whew, that's a relief! :lol:
How/where are you doing the switching?
pgambon
Post by pgambon »
I just use a simple DPDT switch. One side has the 10k the other a 1.5k/22uf. Worth a/b'ing. I'm guessing KF wanted a real tight preamp driving the output stage.
