Missing jumper on the Liverpool layout dwg?
Gibsonman63
Post by Gibsonman63 »
Am I missing something or shouldn't R24 and R23 be jumpered together on the ground side? Also, it looks like an orange wire is coming off the negative side of C15, but I can't see where it goes.
selloutrr
Re: Missing jumper on the Liverpool layout dwg?
Post by selloutrr »
Refer to The schematic
Yes R23 and R24 are joined and share ground with C15.
All 3 components share ground coming off of R23 to lug.
Orange wire should be removed - Most likely a copy and paste from another layout.
As long as we are pointing out wierd things on the Liverpool layout. Take a look at R32a and R32b zoom in.. What is the black line connection for?
My Daughter Build Stone Henge
Gibsonman63
Thanks for the sanity check. I have been verifying my build against the schematic and ran across this one.
The layouts have changed over the years.
I am attaching the ones that show a different wiring.
With the orange wire :)
selloutrr
Post by selloutrr »
They all do the same thing. which one is KF correct?
selloutrr
Post by selloutrr »
Ginger wouldn't be what you would call the normal Liverpool layout.
Well the ole boys called it a clone?
I haven't found out yet how the current layouts came about. Still searching, I could email Ron Worley and ask I guess.
ampmike
Thanx Mark
Post by ampmike »
Thanx Mark,Im starting a Liverpool this week,You guys are a great help,Mikey
