Loss of output sound.
				RockinLocken
After trying a few more keyword searches I swapped out the 12AX7 for 5751 dropped the PI to an AT. Fired it up  and played it a bit noticeable volume decrease not to bad a sound, but lossed the crank,  then zip to a faint distortion sound. What'd I fry this time?????
						Re: Loss of output sound.
I'd say a tube.  You can check which speaker jack you are using,  I found that the one without the ground connection from the output transformer can be weak.
				RockinLocken
It's back
Thanks Keithrick, speaker cable short. I need to get in the habit of check double check and recheck as Paul Ruby says. Thanks again to all.
Glad you got it up and  running!  I feel like an amp "GURU" now
Mr. Ruby has good advice! I've leaned a thing or two from him as well.
