Rocket Build in Progress,Amp running,Sounds Beautiful!!!
ampmike
Post by ampmike »
Hey Guys,Healing up from accident and Ive been working on this rocket,I would apreciate any advice,Thanks rj for all my parts!Mikey
fishy
Re: Rocket Build in Progress,Amp running,Sounds Beautiful!!!
Post by fishy »
I might be wrong but it looks as though the cut cap is wired across the bias resistors.
angelodp
Recoup
Post by angelodp »
Hope for your speedy recovery. This is a good tonic. Its a small matter but be sure and blow out that metal shaving, otherwise coming along nicely.
R18? Check that.
A
RJ Guitars
Post by RJ Guitars »
Mikey,
It's great to have you among us and on the mend, sounds like you went through a lot. Amp therapy is very effective in helping a man heal, something most doctors are not aware of.
I think Fishy is right about the resistor going to the cut control, you need to move the bottom leg of the resistor over to the next turret.
Lookin forward to your report as you bring this from a box of parts into reality.
rj
http://www.rjguitars.net
ampmike
Thanks Guy
Post by ampmike »
Thanks Guys,I missed that,such a small mixup bud would create a lot of hair pulling later on.Thanks again,Mikey
Big Jim
Post by Big Jim »
Good to see you back in action! I will be following your progress. When I build a rocket you can help me out. :D
Jim
ampmike
Post by ampmike »
You got it Brother,Mikey
redshark
Post by redshark »
Awesome amp!! make sure you use a cab with a celestion gold in it...
Cliff Schecht
Post by Cliff Schecht »
I don't like preattaching wires to a board before installing it (minus requisite underboard b+ runs obviously) as it is harder to strip the wires cleanly when installed.
Cliff Schecht - Circuit P.I.
ampmike
New Pics
Post by ampmike »
Need to do some cleaning,I put the caps to close to the switches and had to pull them out.I need to blow this out with the compressor,But just wanted to see if you guys see anything wrong.I dont mind getting yelled at!!Thanks again guys Ill be away for a week so the build will pause,Going down to the Outer Banks,Mikey
ampmike
Cleaning
Post by ampmike »
What is the best way to clean up my work,Could I spray the whole inside of the chassis with a cleaner,I have a brush and rubbing alchohol and some Goop off.Very slow going,I really want it to look clean before I start it up ,Mikey
phsyconoodler
Post by phsyconoodler »
Flux remover,a toothbrush and then blow it out.
Crystal latice or vacuum,that is the question.
ampmike
Back
Post by ampmike »
Hey Guys,Im back in action to finish the rocket this week.One thing,The filter caps neg side go to ground.On the rocket build layout they keep them separate on ground tabs on the rectifier socket.Is this neccesary for any reason?I just put mine together and grounded to the chassis.Thanks Mikey
Big Jim
Post by Big Jim »
Not an expert Mikey but the schematic shows those caps grounded. I am thinking you are OK. Maybe someone else will pipe in.
Jim
redshark
Post by redshark »
You are fine using only one grounding instead of 2. The layout has 2 in case that you use the NOS cinch socket that has 4 soldering tabs, so you can use 2 but if you use a new style socket u can either put 2 grounding lugs or just one, no big deal.
