Yellowjackets in an Express type amp?
mike9
Post by mike9 »
Are the Yellowjacket EL84 conversion sockets OK to use in an Express type amp?
"I fought the Tone . . . and the Tone won"
Re: Yellowjackets in an Express type amp?
Would there even be room inside the cabinet to use those?
mike9
Post by mike9 »
Looking at a chassis - so if applicable I can build a cab to suit.
If you watch the plate voltages it can be done. Many people have used the dual voltage PT.
Not an Express but I am currently incorporating a 260v/300v switch in a customer's Rocket build plus an 18w/36w switch.
All this just adds some usable variable functioning to a amp.
FUCHSAUDIO
Post by FUCHSAUDIO »
Useful in Wreck styles.....a tidbit: Andy Marshall of THD has sold Yellowjacket manufacturing and the trademarks to CE Distribution.
It looks like CE has the short version too. YJShort
I never really paid much attention to these since they first came out.
guitarsnguns04
Post by guitarsnguns04 »
ive put them in alot of different amps..never had any issues other than tube clearance in the cab/ headshell. They are cool enough. I used to use them alot in a boogie I had..50 watt 2x6l6..I used the YJs so I could crank it at smaller gigs. Had the el84s screaming..loved it.
dayn
Post by dayn »
I just picked up a Ceriatone Express. Is there anything that needs to be done to the circuit or can I jsut drop the YJ's right in as I have on other amps?
