How different is a KF-50 from a K-60 type
frischmann
Hi guys,
It's been a while. I'm back at work which means I'm getting close to having dough for another build.
I just can't figure out what to build. I LOVED my Komet K-60 but wanted voicing a little closer to Marshall and an amp that can handle pedals well. The k-60 is picky. I played a 1969 50 watt marshall yesterday and it was great. Insane over tones. Like a komet but with the more organic Marshall vibe.....
Am I describing a KF-50/concorde?
Or would I be better off going with a liverpool/Express and just rolling back the guitar volume to get the rhythm thing going on?
Any layouts of the K-50?
Thanks,
Sorry for all the questions...
Thanks,
Re: How different is a KF-50 from a K-60 type
Your email address didn't work by the way.
Not much difference between the two amps.
The concorde output tranny is 4.8K HTS-5526-1rh 4.8K primary.
There are some changes of using the unused triode to drive the PI need to send you the schematic for you to see the changes.
frischmann
Wow,
I guess I've been gone longer than I thought. Sorry about that.
I just fixed the email.
I'd really like to see any schematics or layouts you have.
Thanks,
Paul
Thanks,
Paul
Paul it looks like the same email address did you save your edit?
frischmann
Interesting,
I changed it again and verified the change.
Sorry again for the trouble.
- LeftyStrat
frischmann, looks like we're in the same boat.
After having build several wrecks and such, I keep coming back to my home-built Marshall, and I keep listening to clips of the KF-50/concorde and it really seems to combine the Marshall vibe with the wreck dynamics.
Anyway, my next build will be the KF-50.
Anyone with info I would be eternally grateful.
funkmeblue
I believe the 3rd stage has 100k plate resistor, a 3k3 cathode resistor and feeds a jtm style cathode follower then into a .02 coupling cap and then a 220k resistor that feeds the phase inverter. The 3rd stage is fed from a 330k resistor. Solid state rectifier
andy_wreck_fan
so concorde is actually a K50 or I'm gettin it wrong?
if so,could some1 mail a layout and BoM to kluks.band@gmail.com?
Yes you are correct Concorde is K50
