PT spare leads
Gibsonman63
PT spare leads
According to the build manual, I do not need the yellow and green leads on the PT. I assume that I just clip them short and heat shrink. Any advice?
Re: PT spare leads
On the Pacific the yellow/green are the 260v taps so no needed for them on the Express amp.
You can cut them short if you want. I tend to keep mine long, cut one just a bit shorter than the other lead and heat shrink tubing over each end and tie them out of the way.
If I want to go back and run a dual voltage system the wires are not cut short then.
Its up to you.
Its up to you.
Gibsonman63
Re: PT spare leads
Thanks. I just wanted to check before I did something that I cannot undo.
