Is the Asteroid able to take other power tubes?
I've read up on the Asteroid circuit but couldn't find the answer. Is this amp able to use 6L6, KT-66, EL-77 or other power tubes or is it an EL-34 only designed circuit? Thanks.
						Re: Is the Asteroid able to take other power tubes?
The Asteroid is designed to accommodate a range of output tubes.
The other similarly-styled amp is for EL34s only.
Thanks for the info.
