1. Fixed bias, diode rectifier, stiffer power amp filtering
2. Ultra-linear output transformer/output stage (Magnetic Components Dynaco A-431 clone)
3. Parallel 1st stage in preamp; added an ef86 in parallel w/the 1st stage 12ax7, each with their own gain pot so they can be mixed independently ( sort of like a permanently jumpered Plexi)
4. High voltage power amp section: 560v on the KT88 plates & 43% screen taps. I used a Hammond 278CX 400-0-400 465ma PT; those '88s eat some current!
5. Mid tone control
6. 12AT7 in PI & tweaked PI values for a big voltage swing to drive the 88's in UL mode.
7. Parallel octal P/P output; I use only 2 tubes with KT88's, but it can take 2 88's/6550's/KT66's/EL34's/6L6's or 4 6L6GC's. I need to add a separate heater transformer if I want to run a quad of EL34 or KT66, because the 278CX only has one 6A heater tap
8. Pre-PI Master volume
I'm finalizing voicing now, and still have to clean up the wiring. It took some doing to tame oscillations, but I got it stable. It is *very* versatile tone wise, and depending on which guitar I use, gets some very high gain (approaching an express). It still retains the beautiful cleans and lower gain break-up of a rocket (and sounds just like one at the appropriate settings, albeit w/a bigger & somewhat tighter bottom), and cleans up amazingly well w/guitar volume knob, even when the amp/guitar combo are set to raging overdrive/distortion. The clean to mild break up with a Strat or Tele are just to die for!
Another thing I added was a switch to switch in and out a screen (bypass?) cap on the ef86 for a switchable boost. I changed the typical values you usually see in an ef86; brought the gain way down so it doesn't overwhelm the parallel 12ax7, and to deal w/microphonics a bit. I got these ideas from Merlin's book (which is excellent, BTW).
Oh yeah, did I mention it's LOUD too! Flat out, it pushes 95W from the pair of KT88's.
EDIT: Added sound clip. It's just me hacking around, but you can get an idea of the sound of this beast and how well it cleans up.
http://www.bryerton.com/misc/kt88rocket ... cket_1.mp3
Here's some pics and the schematic:
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
[img
