6sl7 front end
passfan
6sl7 front end
Post by passfan »
I'm going to experiment with a couple of 6sl7 tubes I've got lying around just to try something different. It will be something more Rocket like in simplicity and maybe later , if this turns out okay an Express style. If anyone has any suggestions they are more than welcome to offer them.
"It Happens"
Forrest Gump
funkmeblue
Re: 6sl7 front end
Post by funkmeblue »
I've built a 6sl7 express a couple of years ago and it's one of my favorites. Great cleans and really sings when cranked, really likes kt66's.
passfan
Re: 6sl7 front end
Post by passfan »
funkmeblue wrote:I've built a 6sl7 express a couple of years ago and it's one of my favorites. Great cleans and really sings when cranked, really likes kt66's.
Did you run loadlines and redesign or do anything special , or just drop in replacements ? I'm going to combine these with a big bottle power section in the rocket (6L6GC's).
"It Happens"
Forrest Gump
funkmeblue
Re: 6sl7 front end
I used Aiken's phase inverter http://www.aikenamps.com/ , I changed the 150k dropping resistor before the 3rd gain stage to 220k and added a cut control. The cut control allows me to crank the presence for more juicy gain, back off the cut to keeps the highs in check. I also paralleled the 3rd gain stage with a 50k plate and a 5k cathode resistor.
passfan
Re: 6sl7 front end
Post by passfan »
funkmeblue wrote:I used Aiken's phase inverter http://www.aikenamps.com/ , I changed the 150k dropping resistor before the 3rd gain stage to 220k and added a cut control. The cut control allows me to crank the presence for more juicy gain, back off the cut to keeps the highs in check. I also paralleled the 3rd gain stage with a 50k plate and a 5k grid resistor.
That'a good stuff , thanks. When you say paralleled do you mean the 50k to the 100k plate load ? That would be the same as a single 75k plate resistor ?
Where did you institute your cut control ?
"It Happens"
Forrest Gump
funkmeblue
Re: 6sl7 front end
instead of a 100k plate resistor I used a 50k plate resistor since I paralleled the two triodes in the 3rd gain stage and I used a 5k cathode resistor. Cut control is the same as the rocket and the comet 60
passfan
Re: 6sl7 front end
Post by passfan »
funkmeblue wrote:instead of a 100k plate resistor I used a 50k plate resistor since I paralleled the two triodes in the 3rd gain stage and I used a 5k cathode resistor. Cut control is the same as the rocket and the comet 60
Ahh... I see...found a use for the extra triode , thanks for the info. I realized the cut right after I hit the post button :oops:
Also, did you go all 6sl7 throughout the preamp or did you retain any of the 12's ?
"It Happens"
Forrest Gump
funkmeblue
Re: 6sl7 front end
all 6sl7
dave g
Re: 6sl7 front end
Post by dave g »
An alternative to paralleling triodes would be to use the 4th triode as a cathode follower after the 3rd stage. If you do this, also drop the 3rd stage's 10k cathode resistor to 2.7 or 3.3k, and change the R7/C8 combo to something like 33k/.01uF or 68k/.005uF.
That's my special sauce. :D
passfan
Re: 6sl7 front end
Post by passfan »
Great stuff guys thanks a million.
"It Happens"
Forrest Gump
dartanion
Re: 6sl7 front end
Post by dartanion »
You may want to consider DC filaments. I did an Express style preamp with 6SL7s that sounds great. I crammed it all into a Pro Jr carcass, so I changed a few things to ensure stability since the chassis is so small.
passfan
Re: 6sl7 front end
Post by passfan »
funkmeblue wrote:I used Aiken's phase inverter http://www.aikenamps.com/ , I changed the 150k dropping resistor before the 3rd gain stage to 220k and added a cut control. The cut control allows me to crank the presence for more juicy gain, back off the cut to keeps the highs in check. I also paralleled the 3rd gain stage with a 50k plate and a 5k cathode resistor.
Was this neccessary or personal taste ?
"It Happens"
Forrest Gump
passfan
Re: 6sl7 front end
Post by passfan »
dartanion wrote:You may want to consider DC filaments. I did an Express style preamp with 6SL7s that sounds great. I crammed it all into a Pro Jr carcass, so I changed a few things to ensure stability since the chassis is so small.
I have a larger chassis out of an older tube organ so plenty of room ti do whatever works best, thanks for the heads up.
"It Happens"
Forrest Gump
funkmeblue
Re: 6sl7 front end
it was for personal taste. Just trying to make up for some of the loss in using 6sl7's
dartanion
Re: 6sl7 front end
Post by dartanion »
Octal twin triodes can be noisy, hence the DC filaments. There is still plenty of gain even without another gain stage. You may also have to weed through a bunch of tubes to get non-microphonic, usable tubes.
