6.6K Transformer in a Liverpool?
RJ Guitars
Post by RJ Guitars »
Some of you may have been following the recent transformer discussions going on here at AGF/TAG.
In preparation toward stocking transformers, I've been on a mission to learn all that there is to the Trainwreck transformer history. I've made a few discoveries and yet confident that there is still much more to be learned.
It appears that Pacific only made one transformer set for Trainwreck. They did not and do not have available any output transformer for Trainwreck style amps except the 6.6K primary that we typically refer to as "The Express" output transformer.
Does anyone know if there was ever a Liverpool built with these 6.6K trannies or is it possible that Liverpools were built using another companies output tranny?
The 250-0-250 tap on the Pacific power tranny would be right for either a Rocket or a Liverpool. If we assume some variant of the Dynaco 470 is the right output tranny for a Rocket then that only leaves the Liverpool output tranny as a mystery.
My info came directly from the top at Pacific so I have good confidence in it. I am curious if anyone can offer up anything more.
thanks,
rj
http://www.rjguitars.net
funkmeblue
Re: 6.6K Transformer in a Liverpool?
Post by funkmeblue »
I always thought that the early liverpools used the same stancor 3801 as the express. The 1985 natti mae has a grey output, "looks" like the same one in the express.
UR12
Post by UR12 »
funkmeblue wrote:I always thought that the early liverpools used the same stancor 3801 as the express. The 1985 natti mae has a grey output, "looks" like the same one in the express.
Stancor also had a 3800 tranny that looks just like the 3801 (even had the extra taps for 250/?? ) except it had a pri imp of 5k. I used one in my Liverpool and love it so much I bought the amp back from the guy I sold it to. mine is a Ginger clone so I am sure it is a little different than the Hattie Mae
RJ Guitars
Thanks guys,
I am familiar with the Stancors (just traded for an amp with a A-3801) and no doubt the A-3800 & A-3801 Stancors provided output for some of the wrecks as well as seem to be what the Heyboers we use are patterned after.
I am not familiar with the gray transformers that folks mention every now and then unless maybe some of those Stancors are gray. All the ones I am familiar with are black.
I have seen Triad transformers that are gray and have heard that those were used in some of the old wrecks. I don't know if this trivia implies that both Triad power trannies and output trannies were used. The only piece of trivia I found on them was that they had a 115V primary.
In my discussions with Pacific they said that they developed their Trainwreck trannies about 20 years back. So from 1989 on it seems reasonable to assume that the Express builds used the Pacifics. It's not clear that they know whether the Liverpool amps used their trannies or not.
I've read a couple pieces of info that indicate that there might have been some Liverpool amps made using the Dynaco 470 like the Rocket amps used. I don't have any pictures or documents to back that up but after 1989 I am curious what output tranny might have been used in a Liverpool.
Thanks again for the discussion,
rj
I have one set of gray Pacific trannies for Express and the lastest I got from you rj are black. So not sure why that is.
What era is Glen's amp from?
1989 isn't it.
rawnster
Post by rawnster »
M Fowler wrote:I have one set of gray Pacific trannies for Express and the lastest I got from you rj are black. So not sure why that is.
Funny, the set of pacific trannies I got from them a few months ago was a color mixture: PT=black OT=gray.
funkmeblue
Zippy
Post by Zippy »
Ummmm, different color paint? :lol:
It's easy enough to remove the bells and paint them however you like.
UR12
Post by UR12 »
Some of the Stancors were gray and some were black
funkmeblue
according to 67 plexi ginger had a stancor 3801
JamesHealey
Post by JamesHealey »
I used to work for a shop that had ginger pass through it a few years back, I'm trying to get a guy who works there to dig out the pics if possible/if they're still on the computer.
We'll see could be a big help.
RJ Guitars
I don't know where Ginger falls as far as which year she was built but any picture of here is interesting either way. If we had info on any info or pictures on Liverpool amps built post 1989, that would go a long ways toward understanding if Pacific transformers were used in them.
thanks,
rj
funkmeblue
ginger was the very first 1982.......stancor quit making the 3801 in 1989
