Airbrake schematic or layout
sliberty
Re: Airbrake schematic or layout
Post by sliberty »
It is much more affordable when you leave out the rheostat. The bedroom mode is not really that useful IMHO due to excessive buzziness. Personally, I'd rather use a decent distortion box, and just turn the volume really low. But the Airbrake is useful for that small drop in output (a few db) without changing tone. It is also good for protecting your speakers when their rating is marginal.
Abstract
Post by Abstract »
Nevermind
:wink:
dehughes
Post by dehughes »
rawnster wrote:I thought it'd be interesting to price out the parts based on the above diagram:
1. $9.83 Mouser# 588-L100J25RE: 100 Watt/25 ohm: Ohmite 270 Series
2. $17.42 Mouser# 588-D100K-25: 100 Watt/25 ohm: Ohmite 210 Series
3. $31.38 Mouser# 588-RJS150E: Ohmite Power: Rheostat: 50Watts: 150 ohms
4. $4.76 Mouser# 10WA365: Lorlin Rotary Switch: 2 pole: 6 position
5. $2.24 Mouser# 588-12-E: Resistor Mounting: brackets 4 needed
6. $3.28 Mouser# 588-2125E 2 extra lugs
7. $13.23 Mouser# 546-1444-14: 5" X 9" X 2": Hammond spot welded aluminum Chassis
8. $5.09 Mouser# 546-1434-14: 5" X 9": Hammond aluminum chassis cover
9. $1.63 Mouser# 75-715P400V0.1: Capacitors 400volts .10uF 5% ORANGE DROP
Total: $88.86
That's a doable price....compared to spending 3x cash on certain "name brand" products.
You gonna build one??? If so, I'd like to get in on that....
Tempus edax rerum
rawnster
Post by rawnster »
Total: $88.86
Hey David, I'm thinking about it. It'd be a nice companion to this raucous Express.
dehughes
Post by dehughes »
Total: $88.86
And I'm thinking about it as I don't want to do the master volume thing anymore... Let's do it!
That is, unless someone knows of a better attenuator that one could use/build...
Tempus edax rerum
DustyBadlands
Airbrake
Post by DustyBadlands »
Made mine over the weekend with some waterslide decals.Works great! Thanks for airbrake schematic. DB :D
RockNRollDr
Post by RockNRollDr »
Could somebody send me a layout of this thing. Thanks.
jaysg
Post by jaysg »
I wonder about using the Alpha or Lorlin plastic switch. The Z uses that, but I've seen pics that look more like a ceramic switch. Dunno. I guess I'd like to see 1A@125V.
Also, has anyone found an alternative box with vents?
RockNRollDr
Can someone send me the layout of this, thank.
zoso503@hotmail.com
bnwitt
Post by bnwitt »
The layout is on page 6 of this thread.
Great things happen in a vacuum
dehughes
Re: Airbrake
Post by dehughes »
DustyBadlands wrote:Made mine over the weekend with some waterslide decals.Works great! Thanks for airbrake schematic. DB :D
Nice man. Where did you get your enclosure, and what are its dimensions?
Also, how did you do your decals? Inkjet or Laser? Did you spray over them?
Tempus edax rerum
Ron Worley
Post by Ron Worley »
jaysg wrote:I wonder about using the Alpha or Lorlin plastic switch. The Z uses that, but I've seen pics that look more like a ceramic switch. Dunno. I guess I'd like to see 1A@125V.
The Ceramic switch is a CK1455, which I got off another thread somewhere....
Ron
DustyBadlands
Airbrake
Thanks dehughes,
I bought the enclosure from mouser,( $13.23 Mouser# 546-1444-14: 5" X 9" X 2": Hammond spot welded aluminum Chassis) along with the rest of the parts. The decals were printed on 8 1/2 X 11 water slide paper I loaded into my Inkjet home printer with acrylic clear coat Check ebay. I can't find the stuff locally. :D DB.
dehughes
Re: Airbrake
Post by dehughes »
DustyBadlands wrote:Thanks dehughes,
Thanks. Do you find that enclosure to be large enough for the build, in terms of layout and heat, etc.?
Tempus edax rerum
terryrocks
Post by terryrocks »
can someone PM me the schematic? This thread is pretty old, but I'd bet someone still has it
