dartanion wrote:
With all this said, I have built many amps that are identical in components with my own 2 hands. Identical in layout, and all components measured with specification (no greater than 5% tolerance). Do they all sound identical? Absolutely not. Very similar, but I can hear differences between every one of them. Is it the small variations in component values? Is it small variations in layout (a few mm here, a few mm there)? The variables are too great to pin it down and make it a science.
Interesting conversation. Good points made on both sides of the discussion. What comes to mind after reading this comment by Dartanion is that, yes, two amps built with the same listed value parts, and the same brand name of parts, still end up sounding different. True values will vary, and when you add several components in the cicuit that are off by just a little, it might end up being a large difference overall.
This is where I believe Ken had the mojo that everyone is looking for in these amps. In what you refer to as "voicing" the amp. After it was all put together as a good starting point, he would change little things to bring the tone to exactly what "he" wanted to hear.
I know not everyone here starts, and, or, stays, with the exact schematic used by Ken and posted here. I just love how most ppl with a new build just love it and are not going to change anything. Then 2 days later they are back looking a VVR's and "boost mods". It is so addicting.
Hell, it seems each original Trainwreck I have seen documented has subtle differences. All part of the "voicing". And that is subject to each different persons taste.
I used the teflon wire. My amps were too bright to begin with. So I changed a few things to get them to where I was happy with the tone. I think this is a must no matter what components you use. It seems each different guitar or speaker cabinet used completely changes the overall tone of the amp. Just so many variables. Out of curiosity, I am going to try some copper wire coated with PVC for the next build to be able to see if I agree that it makes a difference in sound. Should be interesting.
