Airbrake schematic or layout
sliberty
Re: Airbrake schematic or layout
Post by sliberty »
Man, we need to get this diagram posted somewhere so that this silly dance can finally end. :)
LeftyStrat
Post by LeftyStrat »
Here's a thread on Music Electronics forum that has all the info:
http://music-electronics-forum.com/show ... php?t=4339
Hopefully Omar this is okay, since I'm just linking to a another forum, rather than posting the actual info here. If not feel free to delete this post.
DmitriX
Please Help Schematics Needed
Post by DmitriX »
Hello,
can someone please send me schematics of the airbrake design please. I searched troughtout the entire forum could not find it, did not want to ask or bother any one but I see no other way. Thank you very much
My email: ledz4aiden@gmail.com
Dmitri
dobbhill
Post by dobbhill »
This thread is pretty good, also...
https://tubeamparchive.com/viewtopic.ph ... 8&start=30
D
johnny riff
Post by johnny riff »
hello could I please get a copy of the schematic as well. thanks john
LeftyStrat
If you click on any of the links in this thread, your questions will be answered grasshopper.
JIMI HAIRLESS
airbrake schematic
Post by JIMI HAIRLESS »
Icetech wrote:will email it to ya
Could I bother you for that schematic too please?
lewilson
airbrake schematic
Post by lewilson »
Could I get a copy too please? Thanks
JIMI HAIRLESS
AIRBRAKE WITH 100 WATT PLEXI
rockstah wrote:in other words its safe for my 100w plexi to use this airbrake?
Ken Fisher himself said it was perfectly safe to use with a 100 watter! The airbrake manual confirms this and suggests mismatching the load with a vintage amp:
"When using the Airbrake with older vintage amps, mismatching the load will be a safer way to operate. This will eliminate any overheating of the output transformer. For example, a Vox AC30 or vintage 100 watt Marshall should be run at 8 ohms through the Z Airbrake with a 16 ohm speaker load."
JIMI HAIRLESS
:D
bnwitt
Resistive attenuator
Post by bnwitt »
Maybe it's ok to do this now. If not, I'll retract it.
Great things happen in a vacuum
JIMI HAIRLESS
PREVIOUSLY POSTED AIRBRAKE SCHEMATIC
HiGain wrote:So, does this look correct?
I see 3 resistors in the previously posted diagram?? The above layout however is right on the money!
Jason G aka Jimi Hairless
"...this one goes to eleven."
iwo
Post by iwo »
I'd like a copy of the schem. kreepz@hot.ee
kec
Re: Resistive attenuator
Post by kec »
bnwitt wrote:Maybe it's ok to do this now. If not, I'll retract it.
Nicely done!
Ken
Real guitars are for old people! - Cartman
rawnster
Post by rawnster »
I thought it'd be interesting to price out the parts based on the above diagram:
1. $9.83 Mouser# 588-L100J25RE: 100 Watt/25 ohm: Ohmite 270 Series
2. $17.42 Mouser# 588-D100K-25: 100 Watt/25 ohm: Ohmite 210 Series
3. $31.38 Mouser# 588-RJS150E: Ohmite Power: Rheostat: 50Watts: 150 ohms
4. $4.76 Mouser# 10WA365: Lorlin Rotary Switch: 2 pole: 6 position
5. $2.24 Mouser# 588-12-E: Resistor Mounting: brackets 4 needed
6. $3.28 Mouser# 588-2125E 2 extra lugs
7. $13.23 Mouser# 546-1444-14: 5" X 9" X 2": Hammond spot welded aluminum Chassis
8. $5.09 Mouser# 546-1434-14: 5" X 9": Hammond aluminum chassis cover
9. $1.63 Mouser# 75-715P400V0.1: Capacitors 400volts .10uF 5% ORANGE DROP
Total: $88.86
That's a doable price....compared to spending 3x cash on certain "name brand" products.
