New KF-50 Done tonight...this ones mine!!!
soma_hero
Re: New KF-50 Done tonight...this ones mine!!!
Post by soma_hero »
I've been reading up on these switching techniques as best I can, and I can't find any information on the SSR control circuitry.
Why did you use an inverter instead of the transistor method Mark Huss was using, and where can I read about these circuits. I've looked around and can't find any information on controlling these chips.
I'm trying to devise some multiple switching options for some mods to a couple of my amps.
By the way, the inverter is oriented opposite of the silkscreen?
UR12
Post by UR12 »
soma_hero wrote: Why did you use an inverter instead of the transistor method Mark Huss was using, and where can I read about these circuits. I've looked around and can't find any information on controlling these chips.
I just happen to have about 500 inverters laying around not being used and I created the design with the thought that I could put these to good use.
To control the chip you only need to turn on the led inside the chip just like any other LED circuit.
soma_hero
Post by soma_hero »
Dana have you seen the new line of SSR's from Panasonic? I believe their called PhotoMOS series. Some of them have ON resistances of 1ohm. Yes, 1 ohm.
Bet those would do the job well!
Roe
Post by Roe »
Dana and Allyn, are the omet60 kits available for 240v wall voltage?
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Roe
Post by Roe »
bump on the kits for 240v - I need two
4x12" w/H75s
UR12
Post by UR12 »
Roe wrote:bump on the kits for 240v - I need two
I don't have any in stock but I can order a tranny for 240v operation. Do you not have a 5v tap?
Roe
Post by Roe »
Yes, but both these amps are K60s using the 5v tap for the gz34
4x12" w/H75s
UR12
Post by UR12 »
Roe wrote:Yes, but both these amps are K60s using the 5v tap for the gz34
You'll need the tranny then. I'll see if I can find a suitable tranny that will fit on the board and get back to you.
Roe
Post by Roe »
great!
4x12" w/H75s
sst4270
Kit Availability?
Post by sst4270 »
Dana,
Do you have any more of the SS Switch kits available? Cost?
Application is to switch in a cathode bypass cap (Boost) on the 2nd stage of a KT66 based Rocket.
Please let me know.
Thanks,
Steve
Roe
Post by Roe »
bump on kits
4x12" w/H75s
Dana,
I know you guys are so busy so no problem. I had emailed you about buying a kit for my K60 to convert to foot switch any chance of getting a kit?
Thanks, I keep checking your site for that little amp too.
MCK
Post by MCK »
M Fowler wrote:Dana,
Mark, can you kindly share the URL for Dana's site? I saw it mentioned on a few threads but couldn't find it. Google is not picking it up for some reason. I too am itching for the Lil' Devil... Thanks.
MCK
Post by MCK »
Thank you so much!!! Most appreciated.
