New PCB Express build - seeking advice
Ekometti
Re: New PCB Express build - seeking advice
Post by Ekometti »
Very nice. I'm new here yet I am very interested in this build. How can I obtain / order one?
Erik
mattvon
Post by mattvon »
Hey, thanks for the encouragement! I appreciate it...I can say that wiring heaters is my least favorite part of this build so far, lol...
So here's the latest version...I'm cautiously optimistic with this one. I took my time and really made sure I got as close as possible before splitting the twists.
Solders all test good, though it was a challenge to get some of them seated with the extra-short wires.
Thoughts? Does it pass inspection? :D
[IMG:800:600]http://img.photobucket.com/albums/v519/ ... 192915.jpg[/img]
As frustrating as this has been, I'm really glad you all were honest...I'd MUCH prefer to struggle now than to try and debug an oscillating, humming mess later.
Drew.12345
Post by Drew.12345 »
Nicely done my friend :D
Looks a lot better to me.
You'll be glad you spent the extra time to get this right.
Stick with it and keep everyone posted:)
Your gonna love this amp
:D
Colossal
Post by Colossal »
Really nice job on your heater wiring. Much, much better :!: 8)
mattvon wrote:I'd MUCH prefer to struggle now than to try and debug an oscillating, humming mess later.
The key to success in amp building!
mattvon
Post by mattvon »
Thanks, guys! I appreciate the positive reinforcement...it really is an awesome way to learn.
@Erik: I used the BOM (bill of materials) for a scratch build to source all my parts. The BOM, as well as scratch build layout, schematic, and the all-important build guide can be found here: https://tubeamparchive.com/viewtopic.php?t=5691
A few of the components are going to be a bit different from what's called for on the BOM, but my labeled PCB (found earlier in this thread) should help.
The PCB and chassis (and a headbox) were ordered from rj at http://www.rjguitars.net/
rj has been taking a break, but I believe he's getting back into the swing of things slowly. You can email him for info on those parts.
I believe rj also has the proper transformers as well, although I got mine from a different source.
I've been learning a ton by referencing the original PCB build thread, found here: https://tubeamparchive.com/viewtopic.php?t=17524
Ekometti
Post by Ekometti »
Thanks Matt.
E
Ekometti
Post by Ekometti »
Uh oh. info@rjguitars.net was bounced back to me stating mailbox is full.
Bummer :(
Koop
Post by Koop »
OK, my turn for a PCB-XP question. The kit rj sent me contains 4 diodes, the schematic shows 4 in the rectifier and another one in the bias line. Then there are 6 more in between the power tubes and OT, making 11 total. Looking at Mark Fowler's build in the other thread, it looks like I can see 4 in the rectifier and another in the bias supply. I don't see the OT diodes. Am I short a diode?
Yes you need one more diode (1n4007) for the bias.
I don't use the protection diodes on my output tubes. You certainly can if you like to.
Koop
Post by Koop »
Thanks Mark. That's a common part I should be able to source locally. I don't know why rj only shows 4 in his parts kit.
Koop
PEC Pots
Post by Koop »
The PEC pots came with ground lug adapters, at least I think that's what they are. They're like an extra lug that fits over the shaft housing and are drilled so you can solder a wire to them.
Here's my question...why? It appears to me VR3, VR4 and VR5 ground to the board via existing lugs. What are these additional lugs used for?
rock_mumbles
Post by rock_mumbles »
I don't think you can solder to the PEC pot housings so the ground lugs are included if you want to do the 'pot ground bus' thing
Koop
Post by Koop »
rock_mumbles wrote:I don't think you can solder to the PEC pot housings so the ground lugs are included if you want to do the 'pot ground bus' thing
Thanks. In other words, they're not needed for this build.
rock_mumbles
Correct, with the pcb use the pcb's ground bus.
Colossal
Post by Colossal »
Koop wrote:Thanks. In other words, they're not needed for this build.
No buss bar needed or recommended for the PCB build. Run your pot grounds back to the ground pads provided on the board.
